I had the valve covers off of my flhrc 103 with 8000 miles on it and found that 2 of the valves (I don't remember which ones) didn't appear to be turning ...at least from looking at the wear on the end of the valves where they rub the rocker...at the time I didn't give it any mind..but now I have thought about it..is it anything I should be worried about???
Not sure about scooters but on a car/truck motor, I would go a step farther and check the cam for a lobe that might be ready to crap out.
Oh so that's what he's talking about. I was wondering if bikes did that too. For that matter I didn't even really know is all the cars still did that. But I remember reading about it as a teenager. If memory serves (and at my age it don't always) the lobe is shaped to cause a slight spin of the lifter each lift, correct ?
The one problem I have seen (in cars) with valves not turning is the accumulation of carbon deposits, leading to the valve hanging open, leading to low compression, leading to poor driveability. My understanding is that (again, in cars) the valves will start to turn around 3000 RPM. And, the turning valves keep the sealing surface clean. This problem is mainly found in cars owned by old people that never rev up the engine.
This might be totally useless info for this case, but I thought I would share...
LOL that is so true, but they would if it they were not connected in pairs LOL.
(which would be disastrious by the way)
I looked it up, and my memory was right. The lobes on most auto cams (not sure bout HD) are tapered to cause a slight rotation of the lifter (and valve train to some extent).
It even gave some pics on how to examine the patterns on your cam lobes to see if the taper (and the lifters) had worn out and no longer provided this turning.
If the OP doesn't have that many miles on his cam there is probably nothing to worry about, but it would be interesting to track down if HD does in fact design this rotation into their cams also.
HD roller lifters are not connected in pairs. No rotation of the lifter with rollers lifters or roller cams. Lifter turning is only happening in flat tappet cams. Valve turning is completely separate from lifter turning. The rocker arm activates the valve. The valve may spin due to the action the coil spring imparts on the valve, that's it.
