valves not turning
Old Feb 7, 2012 | 02:44 PM
Guntoter's Avatar
Guntoter
Unless there are rotators on the valve spring retainers, they will not turn. I don't think H-Ds have those, but I could be wrong. Also, if the valves and seats are ground at different angles you do not want rotating valves as it will eventually groove the valve face. On standard lifters, they, and the lobes, are ground to rotate but that is to reduce and even the wear on the bottom of the lifter and has nothing to do with the valves.
Old Feb 7, 2012 | 03:57 PM
R_W_B's Avatar
R_W_B
Originally Posted by qtrracer
HD roller lifters are not connected in pairs. No rotation of the lifter with rollers lifters or roller cams. Lifter turning is only happening in flat tappet cams. Valve turning is completely separate from lifter turning. The rocker arm activates the valve. The valve may spin due to the action the coil spring imparts on the valve, that's it.
Oh ok, the ones I've seen on autos were connected in pairs. Without that you would need a guide or something I would think to keep the rollers straight to the cam lobes. Thanks for additional information though.
Again thanks for that additional data. I've never heard of rotators on the valve retainers either but I'm not an expert on such.
Old Feb 7, 2012 | 04:01 PM
R_W_B's Avatar
R_W_B
These are the kind I used to see as a teenager (during the last ice age).
Old Feb 7, 2012 | 04:42 PM
djl's Avatar
djl
Pretty sure the H-D valves don't turn. You can see that by looking at the valve stem surface and you can see there the rocker arm tip rides. If everything is aligned properly, the wear mark from the rocker arm tip should be centered on the face of the valve stem.
Old Feb 7, 2012 | 04:50 PM
fabrik8r's Avatar
fabrik8r
So why don't we use rotators, on the valves?
Old Feb 7, 2012 | 07:59 PM
bagger76's Avatar
bagger76
Like said before roller lifters wont turn they are locked in by a pin. and on cars the exhaust valve had a rotator on the spring to keep the valve from getting hot spots and HD doesnt turn the valves, besides at 8000 miles i wouldnt even think of messing with my engine unless it was coming apart.
Old Feb 8, 2012 | 08:48 AM
mrfikser's Avatar
mrfikser
Originally Posted by jmacdonald5
...what was the reason to have the valve covers off????...
installed new cams...
Old Feb 8, 2012 | 08:49 AM
mrfikser's Avatar
mrfikser
ok, so its normal....
Mike Lawless
Engine Mechanical Topics
29
Jan 15, 2017 11:22 AM
timber0472
Nov 11, 2011 07:18 PM
taz1957
Dec 22, 2009 10:29 AM
RHillbilly
Exhaust System Topics
11
Aug 29, 2008 09:03 AM
rebelent1
Apr 23, 2006 07:01 PM
