Any body ever have a cam go flat,motor just seems to be losing power and motor sounds flat it has a comp cam in it I know guys who ran comp cams in racecars they had trouble with them going flat just wondering if thats my problem.The compression is still 130.so I dont know what else to check.Any body got any suggestions?
A quick check by lifting the pushrod covers should show if one or more don't seem to be moving as much as they should. Stick it on the lift, pull the plugs, throw it in high gear and turn the engine. Covers can be taped up and a dial indicator could be used if you like to compare lifts between them. Generally it will be visual if you've reached the point of power loss.
Ron
Checking the cam as rbabos described could help. With an evo there are other things to consider. Carb, sumping, ignition timing and timing components. Check that the rotor pin isn't sheared and the advance is working.
Ron
Yes, what he said. Know the specs of your cams to compare. Let us know what you find.
Sumping is when the crankcase starts to get too much oil in it impeding the flywheels and crankpin. It acts like a brake on the rotating parts, especially the rod big ends. General reason is the scavange side of the pump is not doing it's job. This can be varified by pulling he plug at the bottom of the engine and measuring how much oil comes out. I believe it should not be more than 8 ounces or something like that. If that's the wrong amount I will be corrected on that, but you got the idea of what could be happening.
Ron
