Feels Like I'm In The Wrong Gear
Old Feb 10, 2012 | 06:49 AM
btsom's Avatar
btsom
With mine, an 08 96 with 41,000, when the idle temp control kicks in, sometimes the second cylinder doesn't come back on line instantly and there is a definite lack of power during the transition. Also, my throttle body had accumulated a ring of goo in the bore on the inside side of the throttle plate. Cleaning that out seems to have improved transition off idle also.
Old Feb 10, 2012 | 09:59 AM
EricD10563's Avatar
EricD10563
Originally Posted by hover
Call me crazy, but when I changed to the SE compensator, the whole clutch releasing, chug chug feeling went away. the bike is so much better leaving from a stop now.
Thanks for the advice guys will look at a few things and see if I see anything. I wont call you crazy I thought I read others had the same experince. Well soon enough the bike will be going in for service anyway.
Thanks
Old Feb 10, 2012 | 10:02 AM
EricD10563's Avatar
EricD10563
Originally Posted by grbrown
I have found in the past that being really familiar with a bike, as you are, can have its downsides! It may just be your bike is a little off song and, having noticed it, you're noticing it more. Could be something really simple like needing fresh plugs, or air filter, or simply a hug!
I agree I might be paying to much attention.
Old Feb 10, 2012 | 10:15 AM
hover's Avatar
hover
Originally Posted by EricD10563
Thanks for the advice guys will look at a few things and see if I see anything. I want call you crazy I thought I read others had the same experince. Well soon enough the bike will be going in for service anyway.
Thanks
The new compensator makes the bike behave much better at low parking lot speeds. It used to almost surge when crawling through the parking lots, but that's all gone now. Also had to replace the inner primary bearing at the same time. She was making some serious noises in neutral, that's why I tore into it.
Old Feb 10, 2012 | 11:06 AM
mrfikser's Avatar
mrfikser
could it be sumping??
Old Aug 11, 2012 | 11:39 PM
EricD10563's Avatar
EricD10563
You were correct Sir, changed the compensator and that solved my problems.
I posted pictures of what my compensator looked like when I replaced it.
https://www.hdforums.com/forum/touri...ooks-like.html
Old Aug 12, 2012 | 12:28 AM
smithbrl's Avatar
smithbrl
My bike has 71,000 on it and I experience the same thing when it's really hot. I start off in 1st but it seems like 2nd. Once I get moving, everything is fine-it's just a slow start.
I've had the SE comp for 30-40k. A thousand miles ago I changed all the fluids and found some bigger than normal metal chunks (it's usually just fuzz) on the primary drain plug. They looked like tiny wire-about 1/8" long. There were 3 of them along with some other stuff and the fuzz was there also. Dealer said not to worry about it but I don't think it's gonna get any better.
Something is tearing up in my primary, so sooner or later it'll be back at the dealer for troubleshooting. I'll have them give a good look at the comp and if there's any question, I'll have them replace it.
It really doesn't bother me but like you, I notice it and wish it didn't do that.
Thanks for the update.
Sanford
Sep 17, 2012 08:26 PM
GOLGO-13
Dec 6, 2010 11:43 PM
petemac
Oct 25, 2010 05:38 PM
MOSTWANTED
Apr 17, 2008 03:22 PM
moblmowr
Mar 23, 2008 12:19 PM
