Now for the wiring, the easiest part of all. I went to target and purchased a griffin micro usb charger that fits in the cig lighter. It is rated at 5v and puts out 1amp per port. Which is exactly what the Garmin car charger is rated at. It fits flush with the fairing and does not hit the tank during full turns. I also purchased the 18" usb power cable through gpscity for 14 bucks. You cannot use the cable that comes with the Garmin for it is a data cable only trust me I know. Also the 12 inch cable is too short, learned the hard way on that one. Finally you can leave it hooked u all the time for the cig lighter is hot only when the ignition is on or on acc. When you shut the bike off the gps will automatically turn off in 30 sec's when it senses the power is turned off and automatically turn on when you turn on the ignition.
I can't find the cable. What part number is it or do you have a link?
I just have a cheap Garmin though. Mine does have FM Transmit and Blue Tooth capabilities though. I hard wired it into the inside of the Fairing with a right angle plug at the GPS. The Garmin shuts on and off with the key too. http://www.ebay.com/itm/Garmin-nuvi-...item2c57575b0f
Great set up (and great post)....I opted for the Zumo 665 and had it mounted to the fairing. The problem with the fairing mount is that it can't be "angled" if there is glare. I wish I had mounted it like you did.......great work.
Would the Zumo 660 or 665 mount on the same type of mount as the 220 or is their mounting method completely different?
Carl
I think the mounting set up would be different because the 660 and 665 has a powered cradle with the wiring built in...I would talk to the people at Leader before you ordered.
