Battery Cranking Amps
Old Feb 13, 2012 | 03:21 PM
TickTock's Avatar
TickTock
Originally Posted by albngore
I understand from reading on these forums that a low battery will adversely affect several other components. Might be that the cost of a new battery will save lots more somewhere else on the cycle.
I agree and that is why if push comes to shove I will pay the 170.00. I was just trying to get in front of it a bit if I could. I honestly thought with the cranking amps being under 10 that it would qualify as bad - but assumptions, you know what they say.
Old Feb 13, 2012 | 04:31 PM
X Iron Butt's Avatar
X Iron Butt
Go here and download this PDF.
http://www.dekabatteries.com/assets/...39EastPenn.pdf
Some good info on AGM batteries. I keep a copy with my battery testing cht.
You keep saying $170.00. Be sure to look at the other posts here on the ETX30L. It is the same battery made by the same company as the HD battery for less than $100.00 shipped. 3 bolts and it is in. This makes it real easy to get out and in for < $6.00. http://www.autozone.com/autozone/acc...mString=search
Old Feb 13, 2012 | 05:53 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Big Crank batteries can be found at just under $100 delivered.
If not stranded, I would not fork over $170, IMHO.
Search the forum, discussed before.
Old Feb 13, 2012 | 06:01 PM
jeffreydsilver's Avatar
jeffreydsilver
Default Easy Answers
All 12 volt batteries should read 12.9 volts fully charged at rest. A reading of 12.7 volts is a 75% charged battery.
Under a load (such as starting) the volts will fall off. Anything lower than 12.2 to12.3 volts, during the crank, indicates a week battery.
Once running the volts should measure about 14.2 volts. This would be an acceptable charging rate.
Old Feb 13, 2012 | 06:02 PM
jeffreydsilver
Once running (the bike) the volts should measure about 14.2 volts. This would be an acceptable charging rate.
Old Feb 13, 2012 | 06:06 PM
atrain68's Avatar
atrain68
I just received my Big Crank battery mentioned earlier. My stock battery was getting weak and wouldn't hold a charge for very long. The Big Crank battery is the same as the stocker. I paid $92 shipped.
Old Feb 15, 2012 | 08:18 AM
TickTock's Avatar
TickTock
Are the dimensions of the ETX30L the same as the stock HD battery or do you end up having to shim it up inside the battery box to keep it from rattling around?
Old Feb 15, 2012 | 08:38 AM
lionsm13's Avatar
lionsm13
The ETX30L battery is the same one/same dimensions that is what the HD stocker is.
It is made by the same company in PA, just w/different labels for who-ever wants it, Deka, HD, Big Crank, whoever.
I thnk that if you would have to shim it up, you'd be referring to an 07 perhaps?
Old Feb 15, 2012 | 09:54 AM
69z28's Avatar
69z28
My RKC battery checked good but was sluggish starting at times.It never failed but slow to crank.Put a new one in it and it was fine.
Old Feb 15, 2012 | 10:17 AM
TickTock's Avatar
TickTock
Not really referring to any particular model. In the past when I bought other batteries they were slightly different from OEM. If this is exact same, then you have given me a good option to try if I don't get this warranted prior to going on a trip away from my normal riding area.
