PCV connector Grease
Old Feb 13, 2012 | 10:11 AM
Rickr01's Avatar
Rickr01
Default PCV connector Grease
How much Dialectric grease are you guys using on your PCV to ECM connector? Originally I used none because the directions didn't call for it. But later on I read that it is now recommended. The last time I pulled it apart I just brushed a small very light coating on with an artist paint brush. However, last night I watched my buddy squeeze a huge blob in the connector of his new Tuner right from the tube and push it together. It was squeezing out of the connector. He said thats the way its done?? Thoughts? What do you do.
Old Feb 13, 2012 | 10:14 AM
Spur56's Avatar
Spur56
I put a good heavy coat on with my finger, kind of like using KY.
Old Feb 13, 2012 | 11:29 AM
Rickr01's Avatar
Rickr01
No Contact issues?
Old Feb 13, 2012 | 11:34 AM
drukanfu's Avatar
drukanfu
Extremists ! Don't just lightly brush it on and don't just glob it on.......JEEEZZZZ !
Old Feb 13, 2012 | 11:42 AM
Spur56's Avatar
Spur56
No contact issues. The contacts should be made so they make metal to metal contact therefore the grease will not cause any problems with this. The grease is to prevent moisture from entering and to help prevent corrosion of metal contacts. It really does not take a lot, but putting too much should not cause any problems. Most of the Harley connector are silicon sealed, so the corrosion issue is the main problem over time.
Old Feb 13, 2012 | 01:28 PM
Rickr01's Avatar
Rickr01
Thanks. Its the corrosion I want to protect the connector pins from. I also put a little on my throttle body connector to help protect against the intermittent limp mode issues many are referring to. I think I need a little more on each.
CGLTD
Apr 27, 2017 07:34 PM
Bigiron
Sep 3, 2011 04:27 PM
oricko
Jul 20, 2010 06:15 PM
gja
Apr 26, 2010 07:18 PM
maddghost
May 20, 2009 08:46 PM
