07 FLHTP wheel upgrade
Old Feb 14, 2012 | 09:57 PM
GotHog?'s Avatar
GotHog?
Default 07 FLHTP wheel upgrade
Just wondering if anyone knows what all is involved in swaping stock wheels with abs tone ring for aftermarket wheels and matching rotors? Is it even possible or do stock rotors need to be reused. Thanks for all input.
Old Feb 14, 2012 | 10:02 PM
BackAt5O's Avatar
BackAt5O
I drilled off the tone ring rivets then bolted the old rotor to the new rotor to use as a template to drill the tone ring mounting holes. Then I assembled it and installed. Took less than 2 hours and works fine.
Old Feb 15, 2012 | 06:01 AM
GotHog?'s Avatar
GotHog?
Thanks for the info. I was thinking it would be something as simple as that, but thought it would be worth it to ask. What type of rivets did you use to put ring on new rotor?
Old Feb 15, 2012 | 06:20 AM
BackAt5O's Avatar
BackAt5O
I used 3/16" aircraft grade stainless steel nut and bolts.
SC07Bobber
Wheels/Tires
Feb 23, 2018 10:16 PM
Hogpro
Vendor For Sale Classifieds
18
Mar 15, 2016 04:31 PM
StreetGlide515
Oct 22, 2015 07:15 PM
gartec81
Nov 26, 2014 03:51 AM
Cage Dodger
Wheels/Tires
Jan 3, 2013 08:05 AM
