I mounted mine in the middle of the fairins as did Potato-Potato did. The only differenc is I put mine on the top of the fairing with a short 2" ball clamp. You can see in my sig pic, the GPS in the sig is a street pilot, but have sence changed to a Zumo 550.
RAM 2.25" x 0.87" Motorcycle Base with 11mm Hole and 1" Ball
Product Number: RAM-B-252U
use this mount upside down under your clutch perch where the ball faces down towards the ground...
With the 16" apes your up there quite high
Then use a adapter to mount in what ever length you desire under the bars to support your GPS hanging under the bars
paul
