Fuel Filter
Old Feb 20, 2012 | 05:53 PM
toad6301's Avatar
toad6301
Default Fuel Filter
I changed out the fuel filter on my '09 Ultra
a few minutes ago after I had been reading the
threads on taking it out and doing it. I must say
that it was easier than I imagined from seeing
some of the pics from others. I had to have been
overthinking it too much. I was able to change it
out without disconnecting any fuel lines or wiring
what so ever. I am a little over 25K on mileage
and was glad that I did it after seeing how dark
gray/black the old filter was.
Old Feb 20, 2012 | 05:56 PM
k-hook's Avatar
k-hook
Fuel filter's in the tank right? Can you tell any difference in performance?
Old Feb 20, 2012 | 05:59 PM
Gliden's Avatar
Gliden
What did you use to unscrew the ring from the tank?
Old Feb 20, 2012 | 06:04 PM
toad6301's Avatar
toad6301
Punch and ball peen, it came off fairly easy I just
smacked it on each tab a little at a time and it
spun off.
Old Feb 20, 2012 | 06:06 PM
Gliden's Avatar
Gliden
Very good. Thanks Toad.
Old Feb 20, 2012 | 06:28 PM
Bowhunter61's Avatar
Bowhunter61
spun off.
Did you put it back on the same way? I am over due to do this and was wondering what pitfalls there are without having the tool for the collar ring.
Old Feb 20, 2012 | 08:06 PM
toad6301's Avatar
toad6301
YEP, I took it off and put it on
in the same manner.
Old Feb 20, 2012 | 08:21 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
How much did it cost you for all that you needed?
Old Feb 20, 2012 | 09:26 PM
Dionicio's Avatar
Dionicio
No pitfalls to worry about. just be careful while removing the ring. I used some spray silicone prior to removal, and the ring slid right off. It also goes on easily.
Old Feb 21, 2012 | 04:38 AM
jjnoble's Avatar
jjnoble
That reminds me. Thanks
