Installing hdpdplus
Old Feb 25, 2012 | 08:28 AM
52bike's Avatar
52bike
Default Installing hdpdplus
Hi All
I am trying to install a hdpdplus into my 2012 ROAD GLIDE ULTRA.
But after I hooked it all up I could not get the faring to fit on.
After several hours of trying to reposition the wires and plugs I gave up and removed the interface and was able to put the fairing back on.
I think that the wires between the 2 male plugs need to be much longer so the plug assembly can be moved to the side of the radio and further back.
But even then it may not fit under the fairing.
Has anyone had this problem?
If this has been talked about before please post a link as I didn't find much about this unit being installed onto a FLTRU when I did a search.
Thanks
Paul
It's ok I got it
Old Apr 13, 2012 | 07:05 PM
Majic31's Avatar
Majic31
I've got a batwing , so it might be a little different... but I had to position everything UNDER the radio - not to the side...
It still causes problems with getting the fairing on or off... but it does fit very tightly..
I know your post was a while back, and you might have solved the issue, but I just saw your post...
Old Apr 13, 2012 | 07:34 PM
rufasim's Avatar
rufasim
what is hdpdplus. ignore my ignorance
Old Apr 13, 2012 | 07:48 PM
Majic31's Avatar
Majic31
It's an aftermarket iPod interface...
Check it out here (and mods... if I'm not allowed to link here... please delete)
http://onthemovetechnology.com/default.aspx
Outkast6991
Audio Systems
Sep 4, 2017 12:58 PM
CVO-RK
Audio Systems
Mar 5, 2013 07:49 PM
Kbore
Mar 8, 2010 10:34 PM
Neil
Apr 1, 2008 02:30 PM
the_ogre25
EVO
Feb 17, 2008 07:35 AM
