Tire Question
Old Feb 27, 2012 | 03:38 PM
Streetrunner's Avatar
Streetrunner
Default Tire Question
I have a Michelin Commander on the front of my SG. It has 18,000 miles on it and has 2/32nds left before it hits the wear indicator. Do you think it's time to replace it or should I run it closer to the wear indicator before I change it?
I do have a new Metzler 880 Marathon in my garage but I hate to waste good rubber if it's not necessary.
I got 15,000 out of the rear Michelin before I had to change it. I am now running a Metzler 880 on the rear.
Old Feb 27, 2012 | 04:00 PM
tidbit1's Avatar
tidbit1
Change it, it isn't like you have four under you.
Ride safe
Old Feb 27, 2012 | 04:15 PM
buggy's Avatar
buggy
2/32 is barely passing inspection here, I agree you are on 2 not 4 is that extra 1k of rubber worth the gamble?
Old Feb 27, 2012 | 04:17 PM
jeffreydsilver's Avatar
jeffreydsilver
The seasons just starting - just sayin!
Old Feb 27, 2012 | 08:22 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Change it. Rubber gets harder each year. On top of that, your present tire will not be able to channel water properly with no more tread than that. Not worth the gamble at all. Lose it.
Old Feb 27, 2012 | 08:42 PM
DTTJGlide's Avatar
DTTJGlide
He said he has 2/32 "before" it gets to the wear indicator, "not" 2/32 left, that means he has 4/32 of tread depth & most fronts only start with 6-7/32. Unless the tire is more than two years old I'd say it's good for a few more miles, now if you run in cats & dogs downpours every day maybe not. Judge for yourself, but tire isn't worn out.
Briboysr
May 17, 2014 08:39 AM
rufasim
Mar 26, 2013 10:11 PM
Serge A. Storms
Jul 21, 2010 02:37 PM
rsnook
Wheels/Tires
Nov 20, 2009 09:48 AM
sparky_mo
Jun 19, 2008 12:23 AM
