Backrest for a 2011 Limited
Old Feb 28, 2012 | 08:47 PM
TNCarters's Avatar
TNCarters
Just put the adjustable on my 2011 Limited which has the Hammock seat (1" back ). It did not fit real well as it was pushed up against the front of the seat slot and was pushing me too far forward when adjusted to its most back position. I just mounted the adjuster to the bolt under the air deflector and I can just reach under it when riding to change position. Did not want to cut air deflector. I ended up adding new mounting holes and forward support plate to the backrest bracket to move it back 3/4" and now fits the seat and I'm back to original riding position. Have not tried it with the passenger yet so may end up pulling the pad portion off when passenger is with me.
Old Feb 28, 2012 | 09:23 PM
Lowcountry Joe's Avatar
Lowcountry Joe
A video on it, but it does now show you where the base mounts under the seat. But the base mounting is straight forward, no drilling required.
http://www.youtube.com/watch?v=pR4nt1mMnPo
Old Feb 28, 2012 | 09:36 PM
dlrshort's Avatar
dlrshort
I have an adjustable that I took off my 2010 ultra limited when I traded it. I worked great. I will sell it if you're interested. Cant use it on my 2012 Cvo RG.
Old Feb 28, 2012 | 10:04 PM
cdroundy's Avatar
cdroundy
I ran in to an issue with the adjustable mount, it will not work on any tall boy seat I found. It was good with the stock seat. The adjuster was just behind the left side rear air deflector. I found it really hard to adjust and ride at the same time.
Old Feb 29, 2012 | 10:11 AM
lviguy's Avatar
lviguy
I've got the adjustable on my 2011 Limited and had one on my 2008 road King Classic before that. Works well, great for long rides. I had my dealer install it, and I can snap a picture of the control if you still need it.
Old Feb 29, 2012 | 10:16 AM
Airborne350G's Avatar
Airborne350G
Please do.... The instructions do not show how the handle mounts.
Old Mar 1, 2012 | 07:14 PM
2011FLHTK's Avatar
2011FLHTK
HD adjustable. Easy to mount too - do it yourself.
Old Mar 1, 2012 | 07:31 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
HD Adjustable all the way. Adjustment lever bolts on with 2 bolts, my RJ's heat deflectors almost cover it, but on the bike you just drop your hand right to it. No regrets, I would do it again. Also handy that it folds down forward to ease passenger getting on or off if needed. Easy on or off, great with my Sundowner. Makes it easier to back up or up on center stand. Be sure to match pad to your style, if available.
Old Mar 1, 2012 | 08:43 PM
flashracer's Avatar
flashracer
I have the mustang backrest. It matches the seat perfectly.
Old Mar 1, 2012 | 08:53 PM
bmaier's Avatar
bmaier
Mustang all the way, adjustable with a thumbscrew, super easy and clean install, love it
piper59
2014-2024 Touring Models
Oct 31, 2016 12:03 PM
lou33
Touring Parts
21
Feb 25, 2013 04:46 PM
bozo
Jul 10, 2012 02:31 AM
hardcor
The General Motorcycle Forum
May 25, 2012 08:17 AM
halfbreed
Apr 6, 2011 01:29 PM
