Load testing an H-D battery
Old Feb 29, 2012 | 06:28 AM
shortride's Avatar
shortride
Default Load testing an H-D battery
The Battery Tender charges at very low amps, I wonder if a battery load test could be performed using that lead or would the resistance in the wire not allow an accurate load test.
Any thoughts on the subject?
Old Feb 29, 2012 | 06:45 AM
jeffreydsilver's Avatar
jeffreydsilver
Default At The Battery
A battery load test should performed AT THE BATTERY POSTS! A load test is nothing more than a controlled dead short. Testing thru a tender lead would blow the fuse, if not melt the leads.
Old Feb 29, 2012 | 09:12 AM
Uncle Larry's Avatar
Uncle Larry
+1 on what Jeff says .... ALWAYS load test at the source!
Old Feb 29, 2012 | 09:16 AM
TUCCI's Avatar
TUCCI
I strongly agree dont do it!
Old Feb 29, 2012 | 10:07 AM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
I don't know about your bike, but the leads on my Battery Tender are fused for 7 amps from their factory.
The new battery load testers are great, input the battery construction type... lead acid, gel, mat, and the CCA of the battery then it takes about a second to get the CCA available and the voltage
But I agree it is done at the source
Old Feb 29, 2012 | 10:57 AM
shortride's Avatar
shortride
I don't plan on doing it. It was only a passing curiosity. It surely would be convenient with the location of the new model battery location to be able to use the Battery Tender leads. It sure would save a lot of trouble removing the seat and everything on top of the battery.
Thanks for the input.
harleyfiremedic
2014-2024 Touring Models
15
Jan 25, 2018 07:05 PM
Genius
Electrical/Lighting/Alarm
Mar 15, 2016 08:23 PM
jackalsilva
Oct 8, 2015 10:52 AM
tidbit1
Mar 9, 2015 05:41 PM
acchd
Sep 14, 2008 11:35 AM
