Check Engine Light
Old Feb 29, 2012 | 07:46 PM
jh.est1975's Avatar
jh.est1975
Stage III
Default Check Engine Light
Check Engine Light comes on after the bike is been riden for about 40 minutes.... Periodically will stall when in a stand still position. Any advice?
Old Feb 29, 2012 | 07:51 PM
jh.est1975's Avatar
jh.est1975
Stage III
Been having issues with battery as well, could this be the issue? Bike is an 01 FLT
Old Feb 29, 2012 | 08:29 PM
hattitude's Avatar
hattitude
If the battery is bad, replace it and see if that solves the other problems.
The more electronics a vehicle has, the more a weak battery can cause all sorts of "issues".
Old Feb 29, 2012 | 08:35 PM
jh.est1975's Avatar
jh.est1975
Stage III
Plan on doing it tomorrow... thanks for the reply brother.
Old Feb 29, 2012 | 09:04 PM
FlamedFXR's Avatar
FlamedFXR
You need to check for stored codes. Several sensors affect idle and if they are failing will stall bike at idle.
Old Feb 29, 2012 | 09:14 PM
Nute's Avatar
Nute
Check engine light is indicating your problem. Check the codes and see what it is pointing to. May be low voltage but you won't know until you pull the code.
Pcrebuilder
Dec 15, 2014 09:25 AM
cchips
Aug 23, 2014 08:16 AM
DaveJFuller
Jul 1, 2014 08:53 AM
leepetersusn
Aug 22, 2011 07:26 AM
jb bill
Dec 26, 2005 05:28 PM
