Death wobble
Old Mar 27, 2014 | 04:33 PM
  #141
fuma's Avatar
fuma
Originally Posted by mkguitar
if you hit the rear brake, the bike will stand up and go straight
Well, feathering the rear can help if you do it correctly. Stomping on the rear, well... not so good. Grabbing front brake mid-turn will stand you up at slower speeds, but most likely cause a high-side and launch you into orbit at higher speeds.
Old Mar 27, 2014 | 05:32 PM
  #142
bigheadted's Avatar
bigheadted
I agree with this and I "play" a lot when riding. Using the rear brake in corners is one of them. Used properly the rear brake in a corner could help you. Applying too much sure causes the bike to hop ! I want to know how the bike and I are going to react in less than ideal situations and I firmly believe that all my "playing" over the years has saved my bacon more than one time.
Old Mar 27, 2014 | 06:00 PM
  #143
jgrohio's Avatar
jgrohio
Originally Posted by little5150
Did you see the video I posted about Jay Leno talking a little about wheel wobble on YouTube? Its at the end of the video, about 9 minutes in. Check it out. Buy the way I'm smoke free,
The letting go for a straight line wobble is just a way to use an extreme example that you should loosen the death grip that the wobble causes when it starts plus it forces you to drop throttle. Still not applicable to a death wobble in a curve no matter what Jay says IMHO
Old Mar 27, 2014 | 07:16 PM
  #144
MNPGRider's Avatar
MNPGRider
Originally Posted by foxtrapper
I've ridden bikes with pronounced misalignment of the front and rear wheel. While the bike traveled ****-eyed or dog-tracked going down the road, I never found it to induce a wobble. Honestly, I don't see or know of any reason it would. Not saying it can't, just that at the moment, I still have yet to see a good explanation of this claim.
I've had bikes that were prone to wobble. Most of it I was able to trace to weight loading and flex of the mounts. Spindly Vetter fairing mounts, wiggly tail racks, etc. Addressing the weight loading (getting it down lower and closer to the bike) and the accessory mounting flex substantially helped. Since the wobble was a deflection of the front wheel, installing steering dampers and or tightening the steering bearings also helped.
In the case of my own RK, it was the oem play built into the rear swing arm because of the excessive clearance between the swing arm bearing inserts and the swing arm shaft. The drive belt masked this play with its tension, making it undetectable until the belt was slacked. In fact this elastic tension may well have made it worse in the turns, as the swing arm could be deflected against the belt tension, only to rebound against it as well.
I've also watched races with bikes going into death wobbles for reasons I do not know. It does seem to have an almost inherent aspect involving high speeds. Sometimes the bike and or rider recover, other times it goes into a tank slapper and ends in a crash.
http://www.true-track.com/tt_cw_article.html
The above link will take you to a magazine article from 2005 posted on True-track's site, that explains what happens when lateral forces in a turn (curve) compress the rubber mounts and misalign the rear wheel, inducing the wobble caused from rear steering. The whole purpose of any of the many add on stabilizers is to prevent that from happening. But if your bike's powertrain is misaligned horizontally to start with, you will always have rear steer. Lean into a curve and that misalignment can be magnified by the lateral forces compressing the mounts.
Old Mar 27, 2014 | 08:18 PM
  #145
Sqr's Avatar
Sqr
Originally Posted by toketee
This past Sat. I road with 7 other guys, I hate to say two Victories were ahead of me along with a Glide and a Heritage. We hit a left hit a left hand marked 50mph at 70, everone went through like they were on rails. My 05 Electra Glide went into a violent wobble that put me right up to the graveled shoulder. I let off some and trie to hold her into the turn, looked real bad for a bit. I was thinking this is really going to hurt, hope I don't get paralyzed. By leaning real hard I made it. The guy behind me on another Heritage pulled up on the side of me and said what the hell was that. I said death wobble, he said it was close to being just that, he didn't think I was going to make the turn. Scdared me real bad, rode the rest of the way home like everyone else except didn't try the hot turns, don't know if I ever will. The wind was blowing, don't know if that was a factor on the batwing.
I nearly suffered an identical fate a couple years back. After visiting the "Tail of the Dragon" we where making our way back on the Blue Ridge when a couple of us began to ride like we stole them. Entered a left turn and the bike shook like a flat tire and after getting it back in line I dropped off the asphalt and onto the 3 foot wide grass between the road and wooden guard rail and a substantial drop. I backed off on the gas and traveled down the grass for a bit until I hopped back onto the road. I didn't have time to drop a load in my pants, but had enough time to think that the ivy growing on the guard rail looked cool.
After we came to a rest stop my buddy who was behind me asked, "what the ef was that"? I knew right away what the cause was as another buddy of mine mentioned this death wobble to me.
I have since ordered a True Tracks for my 07 SERK and will install it on the next long road trip I take.
Mchad
Nov 1, 2016 12:02 PM
Prodaytrader
Jun 14, 2010 02:22 PM
wannabe
Nov 13, 2009 06:00 PM
Sanford
Apr 24, 2008 08:35 PM
Kern
Sep 3, 2006 05:01 PM
