Saddle Bag Latches-Problems
Old Mar 6, 2012 | 08:52 PM
FL-kruzen's Avatar
FL-kruzen
Default Saddle Bag Latches-Problems
Is there a way you can tighten and/or adjust the saddle bag latches? It seems when I hit a bump in the road the saddle latches pop up. Has anyone had this problem?
Any advice would be appreciated.
Thanks
Old Mar 6, 2012 | 08:59 PM
dawg's Avatar
dawg
Can replace the spring.
Old Mar 6, 2012 | 09:00 PM
Potato_Potato's Avatar
Potato_Potato
It may help to take off the canvas tethers and reinstall them either upside down or turned 180 degrees. Also, although I don’t always do it, locking the bags may help.
Old Mar 7, 2012 | 04:03 AM
jjnoble's Avatar
jjnoble
You are not closing them properly. Make sure the lids are seated properly before you close the latch. If they do not snap, they are not closed and they will pop open. That happens when the two tabs on the lid are not properly positioned under the hooks on the bags. Play with it a little and notice the mushy feel and the snap feel, if it feels mushy when you close the latch, they will pop open. If they snap closed then they will not pop open.
Old Mar 7, 2012 | 04:44 AM
riteway's Avatar
riteway
I always lock mine...You never seem to find out that they opened till its to late...Like your best hoodie is gone along with your shock pump wrapped inside....
Cheap peace of mind!!Just lock them...
Old Mar 7, 2012 | 07:02 AM
katobird's Avatar
katobird
My Saddlebag sping rusted and broke.
Replaced it and it is alot tighter when it goes over center.
But then again i've latched it without the 2 "clips" on the inside and yes it will pop open
Old Mar 7, 2012 | 07:33 AM
hemel's Avatar
hemel
That was happening to me as well. I found that the canvas flap was not folding over properly, getting bound up in the latch. Just make sure it's pushed over away from the latch . Worked for me , hope it works for you.
Old Mar 7, 2012 | 07:35 AM
1flhtk4me's Avatar
1flhtk4me
Be sure the lid teather is tucked in.
Check to see if the lock latch is not hanging up.
Old Mar 7, 2012 | 07:42 AM
Bleachey's Avatar
Bleachey
+1 on locking them.
Old Mar 7, 2012 | 08:02 AM
Texas Fat Boy's Avatar
Texas Fat Boy
I agree with hemel: Make sure this flap folds over towards the inside on top of your stuff in the bag.
and like others have said, if it isn't snapping shut it's not locking properly.
