Battery won't charge
Old Mar 9, 2012 | 09:56 PM
Tinman265's Avatar
Tinman265
Originally Posted by speakerfritz
Thats right...don't know why...maybe the smart charger tag the battery as shorted.
Thats exactly it.... The AGM batteries have such a low internal resistance that the chargers think it's shorted. It's a charger safety thing.....
Old Mar 10, 2012 | 04:43 AM
king1065's Avatar
king1065
I had a dead battery on my 2011 FLHTK. It had been on the battery tender all winter. Brought the battery back to the dealer and got a new one under warranty. Took a ride to the dealer that weekend just to check the charging system. Good to go.
Old Mar 10, 2012 | 07:45 AM
lionsm13's Avatar
lionsm13
Originally Posted by Tinman265
Here is a link to the Optima battey site explaining the problem and how to go about charging a deeply discharged AGM Battery.
http://www.optimabatteries.com/produ...agmbattery.php
Interesting, learned something new today.
How does a battery discharge.
Do new/never used batteries discharge and when does this begin to start to take place?
Old Mar 10, 2012 | 09:26 AM
Lowcountry Joe's Avatar
Lowcountry Joe
That's a good piece of info from Optima. I have an Optima battery (not for the motorcycle) and it seems to be one of the best I have ever owned in terms of holding a charge, charging, and reliability.
Old Mar 10, 2012 | 10:06 AM
Tinman265's Avatar
Tinman265
Every battery has a "self discharge rate". The better the battery materials the lower the discharge rate.
Another thing is AGM battery has a lower full charge voltage, usually under 13 volts. Where "wet" batteries are usually in the mid 13 volt range.
There are more tech tips here:
http://www.optimabatteries.com/produ...t/techtips.php
Old Mar 10, 2012 | 10:33 AM
bradsULtd's Avatar
bradsULtd
You need a new battery...if left in a discharged state for 3 weeks, the plates are sulfated and the battery is toast...
Old Mar 10, 2012 | 11:10 AM
Bobby9621's Avatar
Bobby9621
Read this post, it may help
https://www.hdforums.com/forum/gener...read-this.html
Old Mar 15, 2012 | 08:23 PM
Sandy Mike's Avatar
Sandy Mike
Thanks all for your feedback. Learned a lot about batteries through this post, so I guess there was a bright side to the problem.
Problem is fixed, exactly as described - battery was absolutely flat, below the minimum that would allow the charger to recognize it. Dealership took it in, ran some diagnostics, put it on the machine to get it to take a charge, cycled it for me, and it is working fine now. Back in the bike, bike runs, no problems noted.
Dealer (Deeley's) didn't charge anything for the testing or charging so I am pretty happy with the outcome.
Thanks again for the quick help, nice to know there are so many knowledgable folks out there ready to help.
13RoadKing
Electrical/Lighting/Alarm
Feb 11, 2017 02:31 PM
wscott
Oct 2, 2016 12:57 PM
jefla
Jun 29, 2014 01:30 PM
murph
Dec 12, 2007 10:02 AM
HDF Tech
Dec 12, 2005 08:45 PM
