Sorry another trailering question
Old Mar 16, 2012 | 10:09 AM
White Ice's Avatar
White Ice
I just installed these on my Ultra Classic.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old Mar 16, 2012 | 02:45 PM
kc classic's Avatar
kc classic
Just loaded the bike in the trailer for a trial run. Tied it down the way I have it in the pics on the op. Also tied it down at the passenger floor board mounts. Seemed very solid. When trying to rock the bike it rocked the trailer also.
Going to try and tie it down a little higher also. Where the tank mounts.
Old Mar 16, 2012 | 02:59 PM
easycruzer's Avatar
easycruzer
Default tie points
I Have an Ultra as well and put these on for tie points- and have trailered it many times. Really easy to tie it down with them, takes me 2 minutes. (I Have the plain ones)
http://www.kuryakyn.com/Products/391...Downs-Brackets
Old Mar 16, 2012 | 03:18 PM
jjnoble's Avatar
jjnoble
Originally Posted by kc classic
Just set up my harbor freight chock. Had to modify things a little as my trailer has a ramp built in the floor. So the floor is not all on the same level. I mounted the chock to a board so I can use it in the trailer and in the garage. I had to put a hinge in the board under the rear wheel as that is where the floor changes levels(see pic). I also moved the chock all the way forward in the frame work and then moved the pivot piece forward 4 1/4 "(see pic). All is good with chock easy to get in and out of.
My question is on the down tube of the bike frame there is a piece welded between the 2 tubes. Why can't a soft tie be put around the frame just above this to tie the front end down(see pic)? This looks to be a good place and the tie downs in the floor are in alignment with this point. I have looked at others approach at tying their bike down and some suggest around the fork tube just above the fender bolts. Others suggest the triple tree, there is no way to tie up there on my bike.
Thank you for taking the time to look at this for me.
I don't know about all that chock, tie down stuff, but you have the cleanest wheels I've seen in a while.
Old Mar 16, 2012 | 06:03 PM
kc classic's Avatar
kc classic
That's because I just bought the bike around Labor Day and only have 1100 miles on it.
But I have a ten year old goldwing and those wheels look as good.
sel53
Sep 12, 2016 07:22 AM
1badbagger
Aug 23, 2009 04:43 AM
Getyurmotorunnin
Mar 22, 2009 01:06 AM
MNFatboy
Mar 25, 2008 06:28 PM
dgriffith
Feb 15, 2007 02:01 PM
