2012 FLHTK decel vibration?
Old Mar 16, 2012 | 02:24 PM
Sandy Mike's Avatar
Sandy Mike
Take it to the dealer, that just isn't sounding right to me. I get no vibration at all on decel with my 2011
Old Mar 16, 2012 | 04:25 PM
Lowcountry Joe's Avatar
Lowcountry Joe
The dealer is liable to tell you that "it's normal", but if you feel there is a definite issue, you should take it in and report it. It may not be bad enough now to get out of their "it's normal" range, but if it turns into something more later, at least you will have documentation of your concerns.
Old Mar 16, 2012 | 07:06 PM
STLBagger's Avatar
STLBagger
I had a lot of vibration when decelerating after i did some winter mods. Turned out i had the passenger peg brackets on backwards and it was resting on the primary making it very shaky on decel. I would check to make sure all peg or floor board brackets aren't touching the engine or resting on the frame. Also make sure you exhaust brackets, heat shield clamps, and headers are nice and tight. A loose exhaust could shake the bike around a bit. expecially if the saddle bags are shaking hard. Easy check that costs no money. Hope you figure it out
Old Jul 31, 2012 | 07:43 AM
mwegnor's Avatar
mwegnor
4th Gear
I got a 12 RK classic and just picked up a vibration when clutch is pulled in it stops could it be be my primary chain
Old Jul 31, 2012 | 08:44 AM
11rootbeerrcc's Avatar
11rootbeerrcc
I dont know if this is what you are talking about but I had a wobble in the handle bars on decelleration at about 30 miles per hour. I brought it back to the dealer and they torqued the steering head bearing and now all is well.
cathxiii
May 20, 2017 12:12 AM
Switcharoo
Aug 19, 2013 03:13 PM
Junior_co
Apr 30, 2012 11:56 AM
musicnbikes
Jun 27, 2010 12:09 AM
TexasBikeBoy
Jan 23, 2010 05:37 AM
