My Speed Bleeder experience
Old Mar 17, 2012 | 08:27 AM
wlibert's Avatar
wlibert
I used speed bleeders on all of my performance cars and they are da chit! Haven't put them on the bike yet but will when it's time to change out the pads. Screw all those other bleeding systems, speed bleeders are the way to go.
I get mine from here.
Old Mar 17, 2012 | 11:38 AM
Bruce00's Avatar
Bruce00
Thanks for the writeup and review. I'll make a buy online tonight when I get home, been wanting to get a speed bleeder for my truck and your post was enough for me
Also have been wanting to flush the brake fluid from my 08 RG. But I was under the assumption that with the ABS, you needed to cycle the ABS pump, which required a visit to the local dealer. Am I wrong or you don't have ABS with your Brembos?
Any way
THANKS
Old Mar 17, 2012 | 12:02 PM
Bruce00's Avatar
Bruce00
Just sent PayPal for 3 for the bike and 4 for the truck
Old Mar 17, 2012 | 12:38 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Any way
THANKS
Bruce,
My bike is an ABS bike and there is no issue with bleeding the brakes in the comfort of your own garage. You don't need the dealer for this.
Once you unscrew the speed bleeder about 1/4 turn, simply start squeezing the lever or pressing the pedal, and brake fluid is instantly forced out through the tube and into your container. Just keep fluid in the reservoir and don't run it empty enough for air to get sucked into the valve holes at the bottom of the reservoirs. The fluid goes down really slow with each cycle of the pedal or lever. So you will be able to manage the amount of fluid needed in the reservoir with no problem. Get yourself one of those small syringe bodies to make adding fluid to the reservoir a snap. Don't over tighten the speed bleeder nipple. Once it seats, you will feel it and you don't need much torque beyond the point where it seats. I think you will be satisfied with this product.
Old Mar 17, 2012 | 02:37 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Installed mine today and bleed the brakes. No seepage at all when I removed the rear stock bleeder. The two fronts runs leaked a small amount of fluid out while removing them but the shop rags protected the calipers and front fender.
The Speed Bleeders work as advertised. No issues at all.
If you order them, do yourself a favor and order the bleeding hose also.
Old Mar 17, 2012 | 04:29 PM
Lowcountry Joe
Exactly my experience. The back didn't weep a drop when I changed to the SB nipple, the front did weep a little, but not much.
Old Mar 17, 2012 | 06:43 PM
Bruce00's Avatar
Bruce00
Thanks LC Joe
I've bled many a set of brakes in my time, just never by myself.........lol
I also ordered the hose and 4 extra caps. Probably will never need the caps, but at 10 cents apiece, why not? I'll just throw them in my toolbox
Besides if I do need to order them, the shipping would cost more than the price of the caps themselves
Old Mar 17, 2012 | 07:03 PM
atrain68's Avatar
atrain68
The Speed Bleeders are a great and inexpensive product. They make flushing and bleeding brake fluid a short and easy fix.
Old Mar 17, 2012 | 08:30 PM
Lowcountry Joe
I really like the softness of the optional hose. It makes it easy to slip it on the nipple, and more importantly, when you have a full tube of brake fluid to manage at the end of the bleed, it allows you to "pinch" it off of the nipple when you are done....keeping all of the old brake fluid securely in the tube...exactly where it needs to stay.
Old Mar 17, 2012 | 10:21 PM
joewg3's Avatar
joewg3
I did mine this afternoon. The only pain is keeping the fluid level. Great idea with the bungy chord.
