I need help flhtcse2
Old Mar 16, 2012 | 08:10 PM
MILLER41143's Avatar
MILLER41143
Default I need help flhtcse2
After upgrading cam plate and putting in new andrews 54n cam porting heads valves-springs-milled heads 60 i thought i had a little bit too much valve train noise and after about 200 miles it kept getting louder and i knew the sound was louder on left side (primary)
well tonight after about ten miles i brought it in and video it and noticed it was shaking hard
then i shut it off and checked all fluids and went to start it back and i hear a louder than normal clank on left side and it wouldn sart i tried like five more times and it started once but sounds louder than normal on the left hand side
where do i start and the bike has 17k miles
HERE IS VIDEO OF IT SHAKING BAD BEFORE IT CRAPPED OUT
http://www.youtube.com/watch?v=-RyQVYF_itk
Old Mar 16, 2012 | 08:12 PM
1flhtk4me's Avatar
1flhtk4me
Compensator?
Old Mar 16, 2012 | 08:14 PM
MILLER41143
Originally Posted by 1flhtk4me
Compensator?
would that make harder shaking and keep it from starting
Old Mar 16, 2012 | 08:55 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Could be the starter clutch. When you say it wouldn't start...was the starter turning the motor over and the motor was not firing? Do you notice anything different sounding when you hit the starter button?
If you installed your own cams, and if you used adjustable pushrods, do you think you have the pushrods adjusted properly? Might not hurt to pop off the rod covers and check for lash. If the pushrods are ok, and you are sure it's coming from the left side, then you are going to need to pull that primary off and take a look.
Old Mar 16, 2012 | 09:49 PM
MILLER41143
i replaced the starter clutch a couple months ago
it is starting or turning the motor over fine it just wwont fire up
i will pull primary tomorrow
Old Mar 16, 2012 | 09:57 PM
Lowcountry Joe
What about the pushrods....did you install your cams with adjustables? Maybe worth a look to check and see about excess lash before you take off the primary cover. It could be that your valve timing is not what it should be. And if you used the stock pushrods, do those cams have the same base circle diameter as the stock cams? Just thinking out loud.
Old Mar 17, 2012 | 03:11 PM
MILLER41143
I have adjusted them and I just came back from a 15 mile ride before I videod that clip. The cams are 54 n andrews
Graybiscuits
Sep 16, 2018 01:16 PM
earlrengland
May 22, 2017 11:56 AM
SoFLJoe
May 22, 2014 06:59 PM
expoz85
Mar 10, 2012 05:11 PM
policeoff
Mar 2, 2010 07:26 AM
