need help to fix
Old Mar 19, 2012 | 03:17 PM
jimsflh's Avatar
jimsflh
Wow, I'll bet if you broke down in Quebec, this guy would help you with out making fun of your lack of knowledge of French.
A picture would be really helpful, with out seeing it hard to say if JB weld/Liquid steel would work, do you have any internet savy friends that could help you get a picture up?
It may be possible to engineer it with a fitting and an oil filter relocation kit, any local garage mechanics around you?
Old Mar 19, 2012 | 03:37 PM
Harleypingman's Avatar
Harleypingman
Originally Posted by shooter5074
I'm trying to figure out how you could break the oil filter mount off without bending the crap out of the frame. It's pretty protected.
J'essaie de comprendre comment vous pourriez casser le filtre ŕ huile monter sans se pencher hors de la merde hors du cadre. Il est assez protégés.
Right about now, some of you are really impressed................... don't be...... I used Google Translate
One of the best posts I've ever read--who'd have though that Google Translate would be a useful tool--unlike Service Manuals, etc.
Quebecians are almost all by-lingual--French speakers are a minority in their own country--the guy's pulling our collective legs to suggest he doesn't understand punctuation or capitalization in English. And even French-speakers use commas, paragraphs, and capitaliztion.
The foreign language aside, texters are doing their best to eliminate puctuation and capitalization to our collective detriment.
Vive la France!!!!
Carl
Old Mar 19, 2012 | 03:39 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
But was it accurate?
I was afraid I said "my tuna has a blotch on her spinach, and a turnip can be used as a flotation device in case of a water landing "
Last edited by shooter5074; Mar 19, 2012 at 03:53 PM. Reason: My foot keeps wanting to do the Lambada
Old Mar 19, 2012 | 03:59 PM
mrfuji's Avatar
mrfuji
Default need help to fix
hi when i hit the wood pole .my bike was side way the wood pole just went to the same spot .you remove the oil filter and yes transalation on computer is bad. mrfuji
Old Mar 19, 2012 | 04:04 PM
Harleypingman
You're in luck--HD sells the Service Manual en Francais.
Carl
Old Mar 19, 2012 | 04:05 PM
Terrabella's Avatar
Terrabella
Originally Posted by mrfuji
hi just came back from daytona my probleme take bike off garage for spin hit some black ice hit pole and broke my filter mount who is cast in motor case no insurance on bike is winter can be weld glue tap for fitting and remote oil filter 2008 flhtc need idea thank mrfuji
Don't worry, you'll get it later! DOT approved helmet is recommended.
Old Mar 19, 2012 | 04:10 PM
HogglyWoggly's Avatar
HogglyWoggly
touche'.....it's definitely a tough audience today.
Old Mar 19, 2012 | 04:17 PM
jjnoble's Avatar
jjnoble
This is not bad, lets see you say the same thing in French.
Old Mar 19, 2012 | 04:32 PM
Terrabella's Avatar
Terrabella
Default French Translation
Here it is in French; Hi je viens de rentrer de la daytona mon probleme prendre bike off garage pour spin frappé certains black ice a frappé pôles et cassé mon support de filtre qui est coulé je
Still doesn't make sense!
Old Mar 19, 2012 | 04:47 PM
Uncle Larry's Avatar
Uncle Larry
Sure are a lot of smart a$$ remarks on this thread ... the guy needs some wisdom .... not some wise dumb ... if you got enough out of it to make a wise crack I would think that you should have gotten enough out of the post to make a positive response .... Come on guys!
