need help to fix
Old Mar 19, 2012 | 04:59 PM
  #31
Terrabella's Avatar
Terrabella
Sure are a lot of smart a$$ remarks on this thread ... the guy needs some wisdom .... not some wise dumb ... if you got enough out of it to make a wise crack I would think that you should have gotten enough out of the post to make a positive response .... Come on guys!
You are right, I apologize. It just struck me funny. I'll be more respectful. Sounds like he had a bad situation and just wanted some help.
Old Mar 19, 2012 | 05:05 PM
  #32
Gliden's Avatar
Gliden
Is this a test?
He never said oil filter. Plus I doubt it could be that because its protected by the frame.
Me think he broke air filter cast backplate in motor.
Old Mar 19, 2012 | 05:06 PM
  #33
Gliden's Avatar
Gliden
Send picture. Me tell how to fix.
Old Mar 19, 2012 | 05:54 PM
  #34
Pondskipper's Avatar
Pondskipper
If it is just the threaded piece then it is replaceable.
Old Mar 19, 2012 | 06:07 PM
  #35
wurk_truk's Avatar
wurk_truk
I think your friend is correct. You would have to tap TWO holes but it should work using a remote filter. I would try this first, before doing anything more expensive.
Actually, I would shove paper towels in the two ports and saw off the rest of the filter mount so that it is nice a straight. Remove towel and tap the holes out and try it.
Old Mar 19, 2012 | 07:52 PM
  #36
RHillbilly's Avatar
RHillbilly
You can have it welded
Old Mar 19, 2012 | 08:12 PM
  #37
cdestuck's Avatar
cdestuck
Might get better when he comes down off of his Daytona drunk.
Old Mar 19, 2012 | 09:44 PM
  #38
Ragtop's Avatar
Ragtop
damn, I was going to do that!!!
désolé d'entendre que vous avez rompu votre moto.
get it welded
Old Mar 20, 2012 | 06:32 AM
  #39
mrfuji's Avatar
mrfuji
Default need help to fix
hi went to machine shop last night. the guy said bore the hole for oil line .on the 2 pieces so oil passage is same and do 2 sleeves about 2.5 inches long. push half in case half in filter mount , glue the sleeves and weld the pieces together ,or taping the case for remote filter will check on ebay for the filter bracket , wurktruk as the 120r thank for help all mrfuji
Old Mar 20, 2012 | 08:53 AM
  #40
Airborne350G's Avatar
Airborne350G
This is what it translates to in english:
"J' try to include/understand how you could break the oil filter to go up without leaning out of the **** out of the framework. It is protected enough."
I used babel fish a lot as a translation tool while I was stationed in Deutschland.
Originally Posted by shooter5074
But was it accurate?
I was afraid I said "my tuna has a blotch on her spinach, and a turnip can be used as a flotation device in case of a water landing "
