Front Fork Fluid level FLHX
Old Mar 20, 2012 | 12:58 PM
qtrracer's Avatar
qtrracer
Originally Posted by fabrik8r
Ditch the digital scale and the specific gravity conversion formula, and just get a cheap measuring cup with a fl/oz scale. Bottom line is the linear measurement from the top of the fluid to the top of the collapsed tube is whats critical, doesn't matter how much fluid is left after the linear measurment, or what units of measurement you use to account for what's left over.
+1 , as fabrik8r has stated the only measurement that matters is the air volume left in the forks when collapsed and vertical.
Old Mar 22, 2012 | 02:58 PM
clarkchriston's Avatar
clarkchriston
I agree the vertical collapsed measurement is the one that matters most. does anyone know the measure down with the forks on the bike. I may end up draining the tubes and going with a slightly heavier weight oil. I know the manual says otherwise but I know plenty on here who have simply drained the forks via the drain plug, then refilled the from the top with the forks (and front tire) still mounted to the bike.
Old Mar 22, 2012 | 05:11 PM
jjnoble's Avatar
jjnoble
Originally Posted by sgrider08
10.8 fluid ounces is 10.8 ounces!
I doubt that. Drop the weight and go by volume.
Old Mar 22, 2012 | 09:46 PM
qtrracer's Avatar
qtrracer
In case you are unaware, fork oil viscosity is not uniform, a maxima 10wt wont be the same as a pj1 10 wt or any other companies 10 wt. Also viscosity only slows the fork action down. Air volume left(fork oil level) will change bottoming resistance, higher oil level will increase bottoming resistance and a lower oil level will decrease bottoming resistance.
Old Mar 22, 2012 | 11:57 PM
clarkchriston
Yeah i understand the wt/ viscosity and what it does. I want to switch to a heavier wt oil will to slow the fork action a bit reducing the nose dive effect. I dont want to change the dampening resistance by changing oil volume so i would keep it at what the manual suggests
Old Mar 23, 2012 | 08:06 AM
JRBass's Avatar
JRBass
I used the SE heavy and it really helped with that issue.
Old Mar 23, 2012 | 11:01 AM
fabrik8r's Avatar
fabrik8r
Heavy oil is a super cheap budget technique to mitigate brake dive, but with the simple OEM valves, that heavy oil aslo affects damping, rebound, and ultimately compliance. If you are going to tear it down to change oil, do yourself a big favor and drop in a good set of springs instead, that will be a greater improvement across the board. Better yet add some aftermarket valves with the springs, the whole shebang will only run about $325 if you do your own wrenchin'.
skully1200
Sep 21, 2017 10:47 PM
Russty__
Dec 27, 2016 08:32 PM
AllenW
Apr 7, 2016 06:46 AM
rodzooka
Jan 13, 2013 05:18 PM
mglax13
Nov 21, 2011 04:10 AM
