Does anyone scrape when banking hard in a turn?
Old Mar 21, 2012 | 08:35 PM
  #31
TO34's Avatar
TO34
Originally Posted by jay-s
Thanks for the replies guys, This bike is brand new to me and quite a bit of coin and I intend on keeping it for a very long time so I just wanted to be sure something wasn't set up incorrectly.
I have ridden sportbikes my whole life and am coming off of an '07GSXR 750 and have no problem laying it down in the turns, but its a whole different story on a 875lb, $23,000+ full dresser at 60mph. Kinda brings new meaning to "the pucker factor" the first time it happens.
I will say though I like how solid it feels in the turns like that
Yup I went through that same issue, Busa' & Gixxx's all my life, once you get some more seat time you'll be tossing it around. A good seat & bars that really get you into a good riding position and your confidence in the tight turns will get even better.
I have to say though its nice not have to hung the tank anymore.
Ride it man, you'll be shocked at how well that 875lb's can move.
Old Mar 21, 2012 | 09:37 PM
  #32
flhtupser's Avatar
flhtupser
Yep. Done it many times. Ride on.
Old Mar 22, 2012 | 12:45 AM
  #33
DJFireUSA's Avatar
DJFireUSA
Yeah well.. dragging a board is ONE thing... draggin that damn support bar (which is a "hard part") is not only another story but not acceptable.
Any bike that goes right to hard parts is a major problem. MY 105th Anniv Ultra Classic did it, and my 09 Road King Police does it.
Working on a fix as I type this. I lean the bike too far too often to ut up with this crap.
Old Mar 22, 2012 | 04:10 AM
  #34
SinisterSnake's Avatar
SinisterSnake
I scrape, then to even it out I bounce it off the Rev-limiter.
Old Mar 22, 2012 | 05:31 AM
  #35
shortride's Avatar
shortride
I have yet to ever drag anything. Not even on the Dragon.
Old Mar 22, 2012 | 06:41 AM
  #36
tcarille's Avatar
tcarille
No problem,do it all the time.If by some chance you do not like it,check your shock pressure.The pressure in them can bleed out over time,and adjusting that pressure can change the ride of the bike.
Old Mar 22, 2012 | 08:55 AM
  #37
RPS1981's Avatar
RPS1981
I got to work and looked underneath and the bracket that holds the drivers right side floorboards on has a scrape mark on it.
That's the only part of your story that concerns me a little. I don't mind scraping boards, as they've got some give. But scraping the bracket? Scraping rigid parts (brackets, exhaust, engine guards, etc.) makes me nervous. Too easy to lift a rear wheel.
Old Mar 22, 2012 | 08:58 AM
  #38
Uncle Larry's Avatar
Uncle Larry
You've gotta push the limits once in a while!
Old Mar 22, 2012 | 09:12 AM
  #39
dstrat1's Avatar
dstrat1
I agree, on the left mine drags the kickstand, which gives, on the right it's the hard support for the boards, which puts you in the danger zone, as it unloads the tires....if there is a fix for this, other than removing my floorboard extenders, I would like to do it
  #40
TNCarters's Avatar
TNCarters
Running 1" board extenders on my Limited. Ride fairly conservative and usually do not scrape the brackets. That said yes I have scraped brackets on both sides usually when a corner turns out to be a bit sharper than I expected going into it and I have to lean a bit more to stay in my lane.
