turn signal control module
Old Dec 26, 2006 | 04:48 PM
ironhead1977's Avatar
ironhead1977
Default turn signal control module
Hello all
I need some help. I am looking for the turn signal control module on my 1999 road king. The service manual says it is in the battery compartment but it is not, I cannot find it at all. Any info will be greatly appreciated.
Old Dec 26, 2006 | 05:05 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
Default RE: turn signal control module
I don't know squat about the 99's but on my 06 it is just aft of the battery held down by a spring clip. All you see is the top of it the module hangs straight down so the tilt sensor can work.
When I first looked at it I did not recognize that I was looking at the top only of the unit.
Old Dec 26, 2006 | 11:29 PM
maineultraclassic's Avatar
maineultraclassic
It is normally under the seat, right in back of the battery, under a metal clip that holds it in place. It is about 1" tall, 2" wide, 5" deep.
Steve
Old May 22, 2008 | 06:51 PM
sherbert herbert's Avatar
sherbert herbert
3rd Gear
[8D]REMOVE SEAT,WIRES COMING FROMREAR SIGNALS IS WHERE THE MODULE IS.
Old May 22, 2008 | 08:41 PM
hogdoc's Avatar
hogdoc
Well I hope you found it by now but it not under the seat. It is behind the headlight under the nacelle, grey box about the size of a deck of cards,with a bolt through the middle and a connector on one end!
lil-Lawler13
Electrical/Lighting/Alarm
Jun 10, 2014 10:05 PM
crawford769
Apr 23, 2012 12:27 PM
larsfum
EVO
Jan 12, 2011 11:02 AM
tut60
Apr 6, 2009 01:37 PM
Kenr427
Apr 20, 2008 08:23 PM
