Lower faring removal ?
Old Dec 26, 2006 | 11:02 PM
jbatp92's Avatar
jbatp92
Default Lower faring removal ?
What is the secret to removing the lowers on an Ultra? The lower bolt/bracket is easy enough, where are the bolts for the top portion of the faring?
Are they hidden in the glovebox?
Old Dec 26, 2006 | 11:10 PM
voodoodrug's Avatar
voodoodrug
Default RE: Lower faring removal ?
easy to remove ,there 2 bolts in glove box per each lower. once you do this it goes from a 25min job to a 10-15 min job. hold off on buyingthose quick release bolt sets.imo
Old Dec 26, 2006 | 11:13 PM
jbatp92's Avatar
jbatp92
I found the two nuts in the glove box, but no way to get to the front of the bolt. It looks like the front part of the glove box pops off after these 2 nuts are removed.
Old Dec 26, 2006 | 11:17 PM
Snobal's Avatar
Snobal
Like the others said, just open the glove boxes and remove the two nuts on each side.
By the way, I added a rubber washer (Ace Hardware) to the inside of the lower bolt to protect the bottom of theplastic lower fairings when I put them back on.My clamps seemed to have been screwed too tight when new and the clamp bolt was eating into the plastic. The minor mod seems to solve the problem.
Old Dec 26, 2006 | 11:23 PM
Snobal's Avatar
Snobal
I forgot to say, "Get a service manual!" These things are easy to work on with the step-by-step instructions and lots of pictures.
HD has to havegood service manuals so the "highly trained technicians"working at the dearlerships can figure it out too.
Old Dec 26, 2006 | 11:29 PM
jbatp92's Avatar
jbatp92
Thanks, I will try and remove tomorrow.
SnoRider
Jan 30, 2020 10:26 AM
VazquezFXDP
Oct 25, 2018 01:53 PM
toketee
Dec 15, 2013 05:36 AM
bdavis385
Aug 1, 2013 02:38 PM
Wonkaboy
Mar 14, 2010 10:33 PM
