Edit: My Ign. Switch won't lock in the "Lock" Position!
Old Apr 2, 2012 | 01:26 PM
RollaMo's Avatar
RollaMo
Originally Posted by Twillis
Why would you want to lock your bike in the Accessory position?
Originally Posted by Airborne350G
Wow learn something new everyday. Just tried it on my bike and Yep locks in the ACC and Fork Lock position. Now as to why you would want to lock it in the ACC position with everything on is beyond me. LOL
Can anyone explain why you would ever need this "feature"?
Old Apr 2, 2012 | 03:21 PM
JefFLH's Avatar
JefFLH
I can lock mine without the forks being in the lock position. The Acc can also be locked, nice if you have saddlebag spoiler lights and need to leave the bike for awhile, the lights stay on in the spoilers, also the dash lights stay on for some rear visibility.
Old Apr 2, 2012 | 04:36 PM
jjnoble's Avatar
jjnoble
Originally Posted by shooter5074
Here's directly from the manual
"Locks the switch in either the FORK LOCK or ACCESS switch position. Remove the key for security."
Can not be locked in any other position.
I just checked mine. It will lock in the Access position too. But it will not lock straight up (OFF) position or in the ignition position.
Old Apr 2, 2012 | 11:22 PM
BugBYter's Avatar
BugBYter
The ignition switches changed on the Electra Glides. I'm not sure of exact year but i think 07/08. On my 05 UC I could unlock the forks, move switch to off and then turn key to lock position. The switch would turn freely between off and run. Then if I wanted to lock the forks at a stop, all I had to do was turn the switch to lock and the forks were locked. I didn't need to dig out a key to lock it. Very convenient.
My 12 Limited won't do that. I cannot turn the key to lock when the switch is in the off position.
Old Apr 3, 2012 | 03:36 AM
Manninagh's Avatar
Manninagh
So that you can run the battery flat while preventing any good samaritan from turning the switch to off.
Old Apr 3, 2012 | 08:48 PM
marines267's Avatar
marines267
The ignition switch is centered in the off position where you could turn it one notch to the acc. position or one more notch to start the bike. I want it to lock so that you can't turn it to start it. I can fork-lock it, but it won't lock in the "off" position.
The ignition will only lock in the fork lock position. Read your owners manual
Old Apr 3, 2012 | 08:52 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
You came in late...... it will lock in the lock position AND the accessory position.
Last edited by shooter5074; Apr 3, 2012 at 08:55 PM. Reason: My butt smiles when I fart
Old Apr 5, 2012 | 10:22 AM
brak4222's Avatar
brak4222
I made the same mistake myself when I picked up my new Road Glide Ultra.
+1 to reading the manual
Old Sep 23, 2012 | 08:17 PM
T_Dogg80's Avatar
T_Dogg80
You can lock it in the ACC postition so that if you ever break down you can use your 4 way flashers and lock the bike up. The alarm can also be armed when it's in the ACC with the 4 ways on.
Old Sep 23, 2012 | 08:21 PM
shooter5074
If have to have the ignition on to turn on the 4 way flashers on.......... you can turn the ignition off and the 4 ways stay running.
In fact, you have to turn the ignition back on to turn them off.
1LargeDog
Sep 25, 2018 05:19 PM
usmc68
Sep 19, 2017 06:57 AM
5wheels
Feb 23, 2017 08:42 PM
NewJackCiti
Apr 9, 2014 01:46 PM
citytrucker26
EVO
17
Jun 15, 2010 10:26 AM
