Cleaning Tires?
Old Apr 4, 2012 | 07:26 AM
GMRO's Avatar
GMRO
Default Cleaning Tires?
What do you guys use to clean your tires? To make them black/shiny?
Just the sidewall area. Don't want stuff to get on the tread area right? So the spray car tire cleaner would not be a good choice?
THANKS!
Old Apr 4, 2012 | 07:31 AM
1flhtk4me's Avatar
1flhtk4me
THANKS!
That is ok if you spray it onto rag first then rub onto the sidewalls.
You dont want it dipping wet because it will fling off.
Old Apr 4, 2012 | 07:45 AM
Guntoter's Avatar
Guntoter
I use Pledge on a rag and wipe the sidewalls down. Its just enough to make it black and somewhat shiny.
Old Apr 4, 2012 | 08:19 AM
GMRO's Avatar
GMRO
Thanks to ya's both!!!
Old Apr 4, 2012 | 11:52 AM
piasspj's Avatar
piasspj
Clean tires aren't shiny. I use a brush to scrub them, works good on white walls.
Rubber or belt dressing protects them and makes them look good but not shiny.
Old Apr 4, 2012 | 11:56 AM
kjkustoms's Avatar
kjkustoms
I was on the fence on this one for a while, Pledge? Tire foam ? Then I tried the Harley Black, wheel dressing, yes it is a little messy but it really works and lasts. Check it out.
Old Apr 4, 2012 | 12:09 PM
redmonde's Avatar
redmonde
1st Gear
Default cleaner..wesleys bleach white
I use the old school wesleys blec wite on my rk classics whitewall. I use medical nitrile gloves and spray the cleaner on a rag or old kitchen non stick pan safe scrub pad. I then use a bucket of water and another rag to rinse..twice. Use caution around any think painted powder coated etc..it will damage the finish..it makes blackwalls look great too.
Old Apr 4, 2012 | 12:41 PM
68 Shovelking's Avatar
68 Shovelking
I've been using Westleys Bleche-White on tires for decades. I squirt it on, use a scrub brush on the sidewalls, then rinse off with hose. I've used this product on every type of wheel from aluminum to painted and never had a problem, but I never let it sit around very long. I've never found a product that does a better job on raised white letter tires or white walls.
Old Apr 4, 2012 | 01:06 PM
Zuul's Avatar
Zuul
Default That's the good stuff
I use it too - and it's the good stuff I'm told. In Canada it's packaged by a different name by the same company and sold by Canadian Tire as Simoniz (formerly Formula 409 or something).
ANESTHESIA
Feb 2, 2011 07:20 PM
jlasoftail
Sep 2, 2010 07:10 PM
PHAT A$$
May 13, 2009 10:35 AM
midnight2005
Feb 8, 2009 08:39 AM
thomasf59
Mar 22, 2007 12:50 AM
