Cleaning Screaming Eagle Air Filter?
Old Apr 6, 2012 | 05:59 PM
GMRO's Avatar
GMRO
So now I'm more confused. I remove the filter from the carb and it looks like it has oil in it. Inside the filter and on the rubber seal I see and feel oil.
And the filter element is not white. Sort of looks like it is dark orange inside or a dull pink? Very dull not a bright pink sort of dull reddish?
So do I really have a K&N filter already as I thought? The element is not white and it is not dry and I see no markings in it.
I suspect it is NOT the SE paper dry filter... Guess I should get the K&N cleaning filter kit and some reoil stuff.
Old Apr 6, 2012 | 06:14 PM
hambone51's Avatar
hambone51
I had the stage 1 kit installed on my `02 RK the year I bought it. Dealer never said any thing about the filter/cleaning. Guess who used the K+N cleaning kit with oiling it since then. Never a problem, runs like a top. Should I go with a new filter due to age of filter/my dumbass cleaning with it?
Old Apr 7, 2012 | 06:35 AM
vistavette's Avatar
vistavette
You may have a K&N as Harley has stopped selling their own white fibre filter and the replacement is now a standard K&N. Be careful not to over oil it which is easy to do.
Old Apr 7, 2012 | 06:52 AM
smat45's Avatar
smat45
To dry the filter...
I use a bolt through the hole in the filter and snug it tight w/a nut...slip the threaded bolt in my drill and tighten the chuck...put the filter attached to the drill in an empty bucket...turn it on and let the centrifugal force (spinning motion) displace the water.
quick and easy.
smat
Old Apr 7, 2012 | 06:55 AM
skully1200's Avatar
skully1200
If the filter is a K&N, there SHOULD be a little metal strip on the edge of one of the pleats. Don't remember if its on the inside or outside. On that little metal strip, there is a K&N logo stamped into the metal. Kinda hard to see, but it's there. As said before, K&N oil; Harley no oil.
Old Apr 8, 2012 | 11:58 AM
mac1911's Avatar
mac1911
I just use the K&N cleaner, and skip the oil step.
Old Apr 9, 2012 | 05:26 AM
smg614's Avatar
smg614
As stated earlier, dawn dish soap and warm water. I let mine soak for about 15 minutes. Rinse it from the inside out. HD filter does not use oil.
Old Apr 9, 2012 | 06:39 AM
1flhtk4me's Avatar
1flhtk4me
The K&N will have wire mesh holding the element together.
To dry I let it sit outside in the sun.
Old Apr 9, 2012 | 08:59 PM
GMRO's Avatar
GMRO
Ok, double checked...I have the K&N!
Saw the tiny tag inside the filter that is stamped.
So I can soak in warm water, submerged, with Dawn dish soap, for maybe 15 mins. Then allow to dry.
And get me some K&N oil to retreat the filter. Use sparingly...to not over oil it.
Right???
Every 5K miles?
Thanks road brothers!
Old Apr 9, 2012 | 09:14 PM
clap's Avatar
clap
Thats right , you can get the K & N recharge kit at a Auto Zone or someplace similar. I think they are around $15 bucks
