Cleaning Screaming Eagle Air Filter?
Old Apr 5, 2012 | 03:13 PM
GMRO's Avatar
GMRO
Default Cleaning Screaming Eagle Air Filter?
Folks I recognized that I have the Screamin' Eagle Stage 1 Air Cleaner Kit for the Touring bike on my UC. I thought it had the K&N filter in it.
That said I think my filter needs cleaning or replaced. On page 453 in the 2012 HD Catalogue the write up says the filter that comes with this kit is a "synthetic material that is washable/cleanable".
Is this right? What do I use to clean it? I was going to just get the K&N filter for it and just be done with it since K&N has thier own cleaning/prep stuff for their element.
Any suggestions?
Old Apr 5, 2012 | 03:27 PM
ssmith579's Avatar
ssmith579
warm soapy water, rinse and air dry.
Old Apr 5, 2012 | 04:25 PM
johngp7's Avatar
johngp7
here are the HD instructions for cleaning the air filter:
MAINTENANCE
Air Cleaner Element Maintenance
NOTES
This is a dry air filter. Do not apply oil to the filter element.
When servicing the air cleaner, apply Loctite 243 (blue) to
threads of all fasteners.
1. See Figure 1. Remove air cleaner cover (B) and inspect
the filter element (7) every 5000 mi (8000 km), or more
often under dusty conditions.
2. Clean filter element as follows:
a. Remove and wash element by immersing it, on edge,
in a shallow pan containing enough Air
Cleaner/Degreaser to cover no more than 3/4 the
depth of the filter pleats. Do not let dirty solution get
inside the element. Carefully "roll" the element in the
solution around its perimeter until the entire outer
surface of the filter pleats has been soaked.
b. Remove filter element from cleaner/degreaser and
allow five minutes for the cleaner to dissolve the dirt.
c. From the inside out, rinse the element with cold water.
Shake off excess water, and allow the element to air
dry. Do not dry with compressed air.
3. Install air cleaner element and cover.
-J04339
Old Apr 5, 2012 | 04:27 PM
larsfum's Avatar
larsfum
and oil when done. K&N sells a cleaning kit. You can always use dawn dish detergent to clean it though.
Old Apr 5, 2012 | 04:47 PM
Cornel's Avatar
Cornel
The K&N filters use oil. The Harley-Davidson filter elements are dry-type, they do not use oil as a filter media.
Old Apr 6, 2012 | 04:12 PM
duallydondon's Avatar
duallydondon
Default Filter
Does anyone know where I can get a Harley high flow air filter that is the plain papertype??? It has to be tear drop shape,,,do not want to mess with oiling and reoiling???thanks
Old Apr 6, 2012 | 04:46 PM
vistavette's Avatar
vistavette
DO NOT OIL a Harley "Stage One" filter, they are dry filters. Just wash it and let it dry. I have two so when one is drying the other is in.
Old Apr 6, 2012 | 05:04 PM
Gunnysgt's Avatar
Gunnysgt
The post above is correct, do NOT oil a Harley SE airfilter. You will see they are white when new, K&N have that distinctive pink color. You can use Dawn dish soap to clean a Harley one then just air dry it or if you have a compressor you can help it along with a LOW psi air bath.
Old Apr 6, 2012 | 05:28 PM
Tortoise98's Avatar
Tortoise98
The instructions that came with my stage 1 listed a part number for the cleaner, could not search the number in HD catalog. Finally realized it was the K&N filter cleaner part #. Like the others said, don't oil.
Old Apr 6, 2012 | 05:58 PM
TWIN CAM 96's Avatar
TWIN CAM 96
I'd just toss the screaming eagle & buy a K & N there a much better filter.
