Does my Road king have a rev limiter?
Old Apr 6, 2012 | 08:10 AM
RPS1981's Avatar
RPS1981
The rev limiter is there, and it's set at 5500 from the factory. This is controlled by the ECM. Most tuners, including Screaming Eagle tuners from Harley, Power Commanders, etc., give you the option of raising the rev limit to as high as 6200.
In the case of the Power Commanders, it's not in the "map," which is simply a table of numbers to adjust fuel delivery. It's a separate setting in the form of a check box... i.e., "Increase rev limit to 6200."
I wouldn't be afraid of raising the limit, since Harley engineers were obviously comfortable with a 6200 limit via their SERT & SESPT.
Old Apr 6, 2012 | 08:16 AM
Niblet's Avatar
Niblet
thanks for all the info,,i dont want to try to hit the rev limiter,,just wanted to know if its there,,as the bike kinda stopped pulling for a second so I shifted,,I dont want to screw anything up
Old Apr 6, 2012 | 08:28 AM
hoethree's Avatar
hoethree
Ah, the Vtwin G spot!
Old Apr 6, 2012 | 08:34 AM
mgmmgm's Avatar
mgmmgm
I used to hit the rev limiter on my 07 flstf
Old Apr 6, 2012 | 08:38 AM
petewerner's Avatar
petewerner
Originally Posted by klaybus
I sure wouldn't want to make a habit out of hitting it or for that matter even trying to hit it. No good can come from it IMO.
Same here, plus with the cams we have it has run out of breath back at 4500 RPM. But I love dropping back a bit and shift at 4000 RPM and USE all that torque, love that feeling I have always wanted the bottom end to pull like an unloaded truck tractor with a bunch of gears and 600 ft lb tq. It pulls like that now with a full load of stuff board
Old Apr 6, 2012 | 08:44 AM
DannyZ71's Avatar
DannyZ71
You'll know if you hit the limiter. Especially in 1st or 2nd gear. It will make a grinding type sound and the front end will feel like it fell into a sinkhole. What you felt was probably just the bike running out of power for that gear. I've ridden mine pretty hard and only hit the limiter once, in first gear (because my daughters boyfriend runs straight pipes and I couldn't hear my bike at all). I've never hit it in any of the higher gears.
Old Jun 16, 2023 | 02:22 PM
UncleSoftail62's Avatar
UncleSoftail62
Sorry NAILIT I know this is an OLD post but what do you mean by "when the valves float"? Thanks
Old Jun 16, 2023 | 02:57 PM
RG Pilot's Avatar
RG Pilot
Also known as a “piston kiss!” LOL! It’s when the RPM’s are higher than the speed at which the valve springs can close the valves. One of two things can happen: RPM’s will plateau or the motor will grenade itself when the piston and a valve hit each other.
Old Jun 16, 2023 | 10:42 PM
Highclasshobo's Avatar
Highclasshobo
What probably happened is not your rev limiter but instead your map simply wasn't delivering enough fuel at that particular throttle and RPM. I'm assuming it felt like a limiter but was probably just fuel starved...
Old Jun 16, 2023 | 10:54 PM
Taxgod4u's Avatar
Taxgod4u
I always raise the rev limiter until the rear piston pops throguh the tank and smacks me in the nutz, then back off say 500rpm...
