Description: This is a nice feature for those customers who have an additional bike in the household, or simply wish to tune another bike besides the one that the Power Vision originally married to. Every Tune License will be $199, and you can continue to flash tunes to each licensed vehicle as many times as you’d like. There is NO limit to the amount of ECM’s that can be tuned with a single Power Vision, but again, each ECM will require a license file.
**In order to generate a tune license, we require information from the vehicle you wish to tune. This information can be extracted with WinPV, and then you must submit the information for review and processing via email at this time. You would then receive an Unlock License via email that could be applied to your Power Vision. This process is documented and available for review, so please ask a tech rep for more information, PVtech@dynojet.com
Note>> The Power Vision can only use one Tune License at a time
direct from dynojets website. the only bad thing i can see at this time is that to change the license to use it on a different bike, you have to do that through the winpv software. so if you are on the road, and need to flash, you're still stuck with it being able to flash only one bike. unless you take a laptop with you with winpv and the licenses loaded.
