Some RG mods including PBR-300x2 install
Old Apr 8, 2012 | 10:20 AM
mrwatson75's Avatar
mrwatson75
Default Some RG mods including PBR-300x2 Amp install
I just recently had my inner fairing painted. While doing this, I decided to do a couple of other projects. Installing the Polk MM651s, PBR300x2, garage opener mod, and aux jack mod on the radio. I thought I would share some info/pics/resources so it may help someone out.
Amp Install
PBR300x2-169- http://www.ebay.com/itm/NEW-ROCKFORD...item3f1586a3b5
MM651-Got them on ebay from BigBuyCity-109.75
Adapter rings -49.95- http://hawg-wired.com/product_info.p...roducts_id=133
Grills(Most people will not need these..I no longer had my factory ones)-39.95- http://hawg-wired.com/product_info.p...products_id=84
Hogtunes RG 2channel Amp Bracket-31.99- http://www.bkrider.com/bkrider/skuse...eria=C01020113
Amp Power Kit-20.95- http://www.ebay.com/itm/ws/eBayISAPI...m=200707090576
4 ft 16 gauge speaker wire-2 bucks@ Lowes
I cut the RCA jacks off of the input cable and added 2 ft of speaker wire to the right and left side. I added 2 .250" blades and 2 .187" blades. These connected to the stock wiring harness. I did not need to add any wiring to the crossover/speaker side. As you can see in the pics I mounted the crossovers to the top of the radio.
I did bend these down a little. They seemed to be hitting the outer fairing.
Cross-overs on top of the radio.
New Speaker grills
Aux Jack Mod
http://www.hdbomm.com/Aux_Cable_on_Harmon_Kardon.doc
http://blog.ironacesspeedshop.com/ho...vidson-stereo/
I removed the inductor instead of cutting the trace..seemed safer.
I got the grommet and cable at radio shack.(Be sure you get the stereo cable)
Garage remote MOD
Got info from here:https://www.hdforums.com/forum/4594153-post366.html
https://www.hdforums.com/forum/4594419-post367.html
https://www.hdforums.com/forum/4594433-post368.html
Switch-71764-07-~25
Housing-73103-96BK and 2 pins-~4
I mounted the remote behind the left glove box as shown in the pic. Instead of cutting the connector off and attaching to the remote and added wire and used the mating housing.
Old Apr 8, 2012 | 10:21 AM
mrwatson75's Avatar
mrwatson75
Adding the pics for the garage remote MOD..
Old Apr 9, 2012 | 08:09 AM
mrwatson75's Avatar
mrwatson75
Updated some links in the post
Old Jun 1, 2012 | 02:25 PM
UltraNutZ's Avatar
UltraNutZ
very detailed and professionally done.. good work sir.
Greatsteaks
Audio Systems
73
Jan 22, 2018 07:09 PM
Greatsteaks
Audio Systems
Mar 27, 2016 07:40 PM
alrider
Audio Systems
Dec 18, 2013 01:07 AM
kjelders
Jun 23, 2012 11:07 PM
kjelders
Oct 31, 2010 08:29 PM
