How to get more bottom end
Old Apr 9, 2012 | 04:13 PM
grbrown's Avatar
grbrown
Who ported your heads and what cam does he recommend?
Old Apr 9, 2012 | 11:35 PM
speakerfritz's Avatar
speakerfritz
Originally Posted by harley_guy1995
ok so I got my back back good as new.. i have incredible top end from like 3 to 6 grand.. but crap for low end. i practically have to down shift to 4th at 60 to pick up speed.... im trying to figure out how i could get some more bottom end to it.. this is what has been done to it...
flywheel was lightend and balanced
ev 59 cam
crane ignition
ported heads
10.5 to 1 compression
s&s oil pump and pushrods
kibblewhite valves
barrnett clutch plates and spring
i still have the stock carb and have dumper straight pipes on there...
i just replaced the chain and sprocket in the primary... i wanted to put diffrent gear to get more lower end but the chain was too tight so we had to put a new stock sprocket back on...
thanks for the help
stock is 32T/66T . going to 30T would give you more torque at the rear wheel and make you belt looser. going to 30T/68T would give you even more rear wheel torque and the belt fit would be the same as stock 32T/66T.
Old Apr 10, 2012 | 03:28 AM
grbrown's Avatar
grbrown
I thought stock gearing was 32/70?
Old Apr 11, 2012 | 01:55 PM
harley_guy1995's Avatar
harley_guy1995
they guy that ported my heads is the guy that built my motor... and he also reccomended the ev59.. i ran outta money and wasnt able to put a new carb on i was thinking of going with a 45 mikuni...
he also says that if i put a 2 to 1 on that i would have a significant torque gain.. but i dont like the look of that...
so i think what im gonna do is keep the ev 59.. and start by putting on a bigger carb... i dont want to destroy my fuel economy by changing gears... or so i hear
Old Apr 11, 2012 | 02:02 PM
Chunker's Avatar
Chunker
Originally Posted by Cigarmessenger
Try lots of pasta and wine. Worked for my wife! Just kidding
I heard wedding cake was the worst for that
Old Apr 11, 2012 | 02:05 PM
editbrain's Avatar
editbrain
Different sprockets?
Old Apr 11, 2012 | 02:25 PM
hawgwld1's Avatar
hawgwld1
Stage IV
+1 for the ev46 and 2into 1
Old Apr 11, 2012 | 05:31 PM
harley_guy1995
yea.. in the primary
Old Apr 11, 2012 | 07:32 PM
shakrr's Avatar
shakrr
just had 21 tooth and chain installed today and wow what a difference only have 40 miles so far I wanted a little more of what I already had.
Old Apr 12, 2012 | 05:34 AM
grbrown's Avatar
grbrown
Thumbs up
Harley used to sell an SE primary kit of 21T and shorter chain for TC88s. I fitted one to my Dyna. Gives a 19% increase in rear wheel torque, cheapest tuning aid out there! Reduced gearing to around 20mph per 1,000rpm, which I found a real improvement. Got the motor above an annoying vibration patch just under 3k rpm, when travelling on the open road.
