Repairing Batwing Fairing Mounts
Old Apr 9, 2012 | 01:18 PM
V-RoyD's Avatar
V-RoyD
Default Repairing Batwing Fairing Mounts
I have a spare BW fairing that has a broken off mounting tab. Has anyone repaired one of these? I don't have the broken piece. I was thinking of maybe JB-Welding a deep threaded nut or extension nut??
Old Apr 9, 2012 | 01:41 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Run a search in this forum there are co. that make replacement supports that are much better than the stock supports and are pretty cheap cost wise. I think I've seen them on ebay also. Or Amazon.
Old Apr 9, 2012 | 01:50 PM
Primo's Avatar
Primo
My painter has repaired inner fairings where the plastic surrounding the brass inserts have cracked or broken off. He uses a plastic welding technique.
I do not recall anyone posting your idea but I'd say you have little to lose by trying it.
If it doesn't work you can most likely find a new inner in the $75 range.
Good luck and please post pics and results if you make it work.
Old Apr 9, 2012 | 03:03 PM
iclick's Avatar
iclick
There have been several bracket repair threads posted here over the past three years or so. Here's one that I posted recently that links three threads, plus offers more thoughts on adding a second horizontal bracket on each side to better-support heavier aftermarket speakers.
Old Apr 9, 2012 | 03:30 PM
Primo's Avatar
Primo
I think he's talking about the inner fairing itself not the brackets that support it.
Old Apr 9, 2012 | 03:33 PM
Terrabella's Avatar
Terrabella
There are a ton of post on this subject on this forum. Do a search and I am sure you will find your answer.
Old Apr 9, 2012 | 03:53 PM
SSTuner's Avatar
SSTuner
Try this link: http://www.youtube.com/watch?v=idwKf_4v6pQ
Old Apr 9, 2012 | 06:39 PM
Primo's Avatar
Primo
Problem to me reads as with the inner fairing itself guys NOT the brackets.
I had the same problem but bought a used inner fairing at a motorcycle swapmeet and had it custom painted.
Old Apr 23, 2012 | 06:07 PM
TWIN CAM 96
Originally Posted by SSTuner
Is good
Old Apr 23, 2012 | 10:42 PM
Nute's Avatar
Nute
I'm pretty sure this is what the OP is talking about. If I am wrong I stand corrected. As a matter of interest I have had to replace an insert myself and I also purchased and installed Dan's mounts.
https://www.hdforums.com/forum/touri...erts-pics.html
