Best headlight upgrade for '10 SG?
Old Apr 13, 2012 | 07:36 AM
  #31
SmittyFXDL's Avatar
SmittyFXDL
Thanks fabrik8r. Will using the 60/55 bulb still make a big difference over stock or is the 80/100 still needed? The link you gave states DOT plus headlamp. Is the hella e dot approved now?
Old Apr 13, 2012 | 07:41 AM
  #32
fabrik8r's Avatar
fabrik8r
Sorry that was the wrong refelector, I went back and corrected the link to the E Code, but to answer your question, Yes it will still be better even with lower power bulb because of the inproved pattern.
Old Apr 13, 2012 | 08:21 AM
  #33
2004Sierra's Avatar
2004Sierra
Originally Posted by trackadaptor
Went with PIAA love the idea running H9 in the Low beam
The H9 bulb has almost twice the lumens of the H11 bulb. Its hard to believe going from a 55w to a 65w bulb would almost double the light output, but it does.
You have to modify the H9 bulb slightly to make it fit the low beam socket but it makes a huge difference. Just do a web search on H9 bulb modification, its really simple to do.
Old Apr 13, 2012 | 10:59 AM
  #34
iclick's Avatar
iclick
Originally Posted by MadIrish
My understanding is the 100/80 bulb is "illegal" or not DOT approved. Anyone that uses the E code headlight and the 100/80 bulb have any trouble on the road or with an inspection?
Never. I've run E-codes plus the high-output bulbs in this '07 SG since '08, and had the bulbs in my old RK for nine years. I don't know how state inspectors could check for the bulb rating without removing it? The headlight isn't marked to indicate it is an E-code, so I can't see how anyone would know that either? It looks like any other fluted headlight.
I've also had both in my cars in the past, also with no legal issues.
Old Apr 13, 2012 | 12:24 PM
  #35
ggerline's Avatar
ggerline
I got a HID kit from ultrabrightlights.com 6000k and I love it....sooo much brighter and cheaper than LED option from HD.
Old Apr 13, 2012 | 07:28 PM
  #36
jerren25's Avatar
jerren25
Thanks guys! This is alot of great information that I will have to look into.
Old Apr 14, 2012 | 01:39 AM
  #37
jerren25's Avatar
jerren25
I went with the Hella e code and 80/100 bulbs for now. I will see how that goes. Thanks again.
Old Apr 15, 2012 | 09:28 AM
  #38
jaycanter's Avatar
jaycanter
Default Led
Just purchased new SG and got the HD LED huge difference from stock and love it but it's a matter of preference. worth every penny to me.
Old Apr 15, 2012 | 01:06 PM
  #39
iclick's Avatar
iclick
Please report back once you've given them a test ride at night.
Old Apr 30, 2012 | 09:30 PM
  #40
bigdumbnoitall00's Avatar
bigdumbnoitall00
bump up
