secret decoder ring found??
Old Dec 30, 2006 | 12:51 AM
voodoodrug's Avatar
voodoodrug
Default RE: secret decoder ring found??
I think from what ive read you can always try canned tune from computer and If no like it just take it outand/orhave it dyno'd with tuner.
Old Dec 30, 2006 | 01:44 AM
Dave_B's Avatar
Dave_B
ORIGINAL: voodoodrug
Or with your butt.
Old Dec 30, 2006 | 01:51 AM
HD Renegade's Avatar
HD Renegade
ORIGINAL: Bagger_Dave
Was it worth the money in your opinion? I have an 06' Street Glide that I put Rineharts, PCIII, and a SEAC on, and they used the map on the web site of Power Commander that had the exact setup.
So do you feel that there maps are close, or was there a major difference. Some people have said that there pretty close. I'm just trying to find out if it's worth the money to dyno?
At the time Power Commander did not have a map for my setup, so the money I spent was worth it. Carl's Speed Shop has been tuning bikes for over 30 years, so I knew I had a good tuner to do it. If you are happy with how your bike runs with a canned map then leave it alone and just ride it. I just wanted mine to run well.
Bob
Old Dec 30, 2006 | 02:18 AM
sportyrider1's Avatar
sportyrider1
If you get your power commander from Jamie at fuelmotousa and tell him what you have on the bike he will set it up with a semi custom map that will be 99.9% if you want 100% then its off to the dyno. also if you buy from Jamie then make a change on the bike he will send you a new map at no charge on request.there is a dealer in atlanta who will dyno for $95.00 + but I am not fond of their work. if you decide to dyno find a tuner that you trust even if it is a few dollars more
Old Dec 30, 2006 | 03:38 AM
Dsanchez's Avatar
Dsanchez
I think dynojet claims their canned maps are about 95 %
Old Dec 30, 2006 | 10:03 AM
Longtimegone's Avatar
Longtimegone
ORIGINAL: HD Renegade
PCIII can be programed from your home computer. I am not sure on the SERT as I do not have one. Also, a good Dyno Tuner should be able to tune your bike in 2-hours or less. I was told by the people that did mine it takes longer to tune a SERT. I paid $350.00 for the dyno tune on my PCIII.
Bob
Yes, it is true that a SERT tune will often take longer because you have to stop to download the changes. The SERT is not an add-on and is more tuneable. MySERT dynotuning by a local independent shop frequented by mechanics from Harley dealerships took only 1 and one-half hours. I believe the $250 was money well spent. Between my stage one parts and the excellent tuner, I have torque that many with 95" builds do not have.
Old Dec 30, 2006 | 11:12 AM
wishbonecg's Avatar
wishbonecg
I response to Bagger Dave, I have the same set up as you do. I ran with the canned map from Power Commander and had $150 burning a hole in my pocket so I had it dyno'd. Truthfully, I think it ran fine with the factory map. Now it pops a lot on the decel and hesitates a bit on the accel. I think I will disable the accel fuel pump software to see if I can get it to smooth out. Or take it back to have it dyno'd again (hopefully, at no cost) to get it smoothed out. Also, regarding Fuelmoto's maps. I'm having a hard time seeing where his "custom" maps would be any better than the factory maps. Every individual engine has it's own personality and the only way to tweak it all the way in is to have it dyno'd, no?
Harleypaw's Avatar
Harleypaw
I'm no expert on SERTS, never run one, the power commander with a mildbuildand down load from PC site will be 95% correct, say your bike runs 80hp, you find a tuner that gets you 100% you'll only gain maybe 4hp is the $150 worth the gain. On a mild build a good tuner should be able to tune in no more than 3 runs and normally that's less than 1 hour. Where you run into these 4 to 6 hour tunes are with big inch, high hp builds with highly tuneable exhaust.
Old Dec 30, 2006 | 11:59 AM
HD Renegade
ORIGINAL: Harleypaw
Just my opinion but, I would say that anyone that takes 4 to 6 hours to tune an EFI bike really has no idea what they are doing, or their Dyno is very old. The new Power Commander Dyno machine's do most of the work and take just about all of the guess work out of it.
Bob
Old Dec 30, 2006 | 12:32 PM
sportyrider1
ORIGINAL: wishbonecg
IMO while fuelmotos maps my not be 100% because it is true each bike is unique, he does have maps that the factory doesn't because he is a tuner and keeps a database of all of the bikes he tunes. recently I contacted him for a map for my setup but with fuel economy in my cruising range and they sent me a map that is completely different from the factory dynojet map for my setup and apears to work for what I wanted power top, power bottom mileage in the middle
