Hidden antenna
Old Apr 15, 2012 | 05:09 PM
NECaveman's Avatar
NECaveman
I have the Boom hidden antenna, it works great! Just as good or better reception compared to the stock whip antenna. I live in the midwest, so not a lot of obstructions and interference. If you install yourself, make sure the antenna curved mounting wedge is not mounted below the 1/4" max. If you exceed the 1/4" the fairing bottom will hit the antenna.
Old Apr 15, 2012 | 06:02 PM
Brick0044's Avatar
Brick0044
I zip tied this in my fairing and have great reception.
Old Apr 15, 2012 | 06:34 PM
2>4's Avatar
2>4
I am very happy with mine. I get better reception on my bike than in my car!
Old Apr 15, 2012 | 08:51 PM
SharkBite's Avatar
SharkBite
Mine sucks
Old Apr 16, 2012 | 08:44 PM
vichendrix's Avatar
vichendrix
Originally Posted by Sparky73
I should clarify....The HD hidden antenna is a paperweight now, not the amp. I'm working with Hogtunes tech support for a fix on the RF interference issue.
Sparky73 pm me when you get it figured out please i got same setup am about to install the antenae love to know how to fix if i have same problem
Thanks Vichendrix
Old Apr 16, 2012 | 10:40 PM
Sparky73's Avatar
Sparky73
Thanks Vichendrix
Vichendrix, Drop a note to HogTunes tech support. They put my name on a list and said they will ship me a new amp once they figure out the shielding. I was told 1-2 weeks but I suspect it'll take a little longer than that. Until then, I'll be using my shorty antenna.
Old Apr 17, 2012 | 10:11 AM
murph's Avatar
murph
I took the stock ant. and routed up along the frame. Better reception... I'm guessing because of the frame. Don't know. Anyways, I drilled the mount and tapped it so it would face straight up. You can't even see the ant unless you really are looking for it. It only cost me $2.00 for the rubber plug... Not a bad price and better reception.
Old Apr 17, 2012 | 05:29 PM
PWFD's Avatar
PWFD
I have the most recent updated boom hidden antenna and love it. It works as well as the stock antenna on my RG. When I've been out in the rural areas no lost of signal. I'm very happy with it.
T
Old Sep 3, 2013 | 09:20 PM
longzoo's Avatar
longzoo
4th Gear
Default amplified antenna
I have heard nothing but bad about the amplified antenna (needs 12v) anyone had good experience with them? i been looking on ebay, price looks good but the old adage...."ya get what cha pay for" still rings in my ear.
Old Sep 3, 2013 | 09:27 PM
Iceman24's Avatar
Iceman24
Installed HD Boom antenna in my 09 FLHX this spring and it's horrible. Ran shorty whip before with decent range, but the hidden unit truly doesn't perform as stated on box. Just purchased a 1-male to 2-female y-cable so I can connect the boom powered + short whip in my fairing...hoping this will do the trick...we'll see.
