2003 rebuild 88ci to 103 ci not running right
Old Apr 16, 2012 | 09:13 PM
Ricky06Roadking's Avatar
Ricky06Roadking
Guys the flywheel was damaged. If you have to go into the bottom end a Stroker flywheel is a logical choice.
The SE CVO motors were 95ci then 103ci up to 2006.
Old Apr 16, 2012 | 09:15 PM
Ricky06Roadking
Saying you can't take a 88" motor to 103" is like saying you can't take a 96" motor to 110".
Its done every day
Old Apr 17, 2012 | 08:59 AM
4srco2's Avatar
4srco2
3rd Gear
Yes we did find SE 204 cams were in it. I bought this bike preowned and didnt know any engine mods were done until tear down.
Old Apr 17, 2012 | 03:37 PM
NAILIT RK's Avatar
NAILIT RK
That thing must have been thumping pretty good when you bought it. I have a stock TC 88 RK and it is pretty quiet but if it had cams and a big bore to 95 I think I would notice it...
Any how good luck, sounds like it just needs some final adjustments in air / fuel delivery
Old Jun 26, 2017 | 05:56 PM
Atvs_harleys_rule@yahoo.com's Avatar
1st Gear
Default Idle issues
Originally Posted by AlanStansbery
First thing is to decide on the method you want to use to tune it. There are a bunch of different devices and methods. TTS is one (you'll need a dyno tune). ThunderMax with auto tune is another (not as precise as TTS, but you start with a canned map, and the TMax tunes itself). These are just two of many methods out there.
You're wise to park it until you get this sorted out. "Spitting through the throttle body" sounds like it's lean as heck. If it was me, I'd throw a ThunderMax at it. But there's a lot of different opinions. In any case, you're looking at from a couple hundred bucks to over a grand.
Alan
99 Electra glide 88ci to 103ci. Problems idling.... 4 3/8 screaming eagle crank 103 cylinders and pistons 202.25 cams stock compression replaced ecm and tuner with the thunder max ecm and tuner have 30 miles on rebuild of motor issues idling
Old Jun 26, 2017 | 08:25 PM
Kburgad's Avatar
Kburgad
It all depends on what your coming from. I went from an 81 ironhead and shovelhead chopper to an 88 Twinkie. I thought it was a powerhouse. Then I got a used 09 bagger knew it had a big bore pit in at the dealer with 103 jugs and se cams. Thought it was fast coming from cammed 88. Come to find out after talking to the old owner its got 106 big bore and 551 cams. And 106 ft lbs of torque. Didn't know I was riding a rocket. Its all in the comparison.
Old Jun 26, 2017 | 09:12 PM
Max Headflow's Avatar
Max Headflow
You would be better off creating a new thread here..
https://www.hdforums.com/forum/the-dyno-room-190/
Did you replace the throttle body in the process?
What are 202.25 cams.. List every thing replaced..
Drumlord
EVO
11
Oct 24, 2018 08:10 AM
4srco2
General Topics/Tech Tips
Apr 16, 2012 11:45 AM
4srco2
Apr 16, 2012 11:37 AM
cmashark
Sep 20, 2009 09:56 AM
Bluzmn59
Aug 8, 2007 09:37 AM
