General RPM
Old Apr 16, 2012 | 05:04 PM
birdmandave's Avatar
birdmandave
Default General RPM
I'm sure there is no exact formula, but would like others input on RPM and shift change. I can't shift to the moco MOM ranges. I've also read many threads on HDForum that lugging the engine is very bad. With that said, other than 1st, what's the lowest rpm before downshift, and what's the highest before upshift. I try to stay at 2500 for most speeds, don't know where I got that but the bike sounds good.
Thanks
01 UC, stage 1, 7" NC V-Stream, Hogtunes. Still can't figure out how to post picture.
Old Apr 16, 2012 | 05:22 PM
redman2636's Avatar
redman2636
I personally shift between 3000 and 3500, cruise about 2500 and downshift if rpms fall below 2000. Don't know if that's good or bad but it's what feels right.
Old Apr 16, 2012 | 05:25 PM
Snuffy1's Avatar
Snuffy1
Thumbs up
What he said.
Old Apr 16, 2012 | 05:30 PM
one-up's Avatar
one-up
Old Apr 16, 2012 | 05:34 PM
ClassicBill's Avatar
ClassicBill
There are a lot of variables that come into play on when to up/down shift. with a basically stock bike like yours you can run around at about 2500 rpm as long as you are not heavily loaded or climbing steep hills. Each shift on your bike should change rpm's approx 500 rpm's, so figure your shifting from there. If you have a heavy load and/or are climbing steep hills you will want to run a little higher rpm's. the bike won't be hurt by running up higher in the rpm's.
Old Apr 16, 2012 | 08:31 PM
birdmandave
Thanks for all replies. Won't be my last HD, but gotta make it last until the OL says let's look at newer ones.
Old Apr 16, 2012 | 08:34 PM
Silverback2011's Avatar
Silverback2011
Generally what i do too.
BlackKnight67
2018+ Softail Models
Apr 10, 2019 08:57 AM
sbebenelli
Jun 30, 2018 09:21 PM
Peter Chadwell
Jun 7, 2015 03:38 PM
DGDyna
Apr 7, 2009 06:16 PM
grinner
Nov 14, 2007 06:24 PM
