Oil leak...
Old Apr 19, 2012 | 06:24 PM
brummie's Avatar
brummie
Default Oil leak...
Just shone a light down behind the primary, and just at the rear of the tranny I can see where the oil is coming out the rear of what looks like a shaft of the tranny. I have been using red line heavy..in a 2005 road king 10,000 mile on it....is this an expensive repair, and is it safe to let it go for a while, as long as I keep a check on the oil...thanks brummie
Old Apr 19, 2012 | 08:37 PM
dawg's Avatar
dawg
Are you talking about the shifter shaft seal, or around the tranny sprocket?
Old Apr 19, 2012 | 09:08 PM
brummie's Avatar
brummie
Default Oil leak..
Hi...I do not really know, I do not think it is the shifter though....it is just down low over the primary cover, right against the back of the tranny..it looks expensive though....thanks. Brummie
Old Apr 19, 2012 | 10:04 PM
RK Joy's Avatar
RK Joy
Just the gasket seeping around the cover? Screws loose?
Old Apr 19, 2012 | 10:20 PM
SOCALHD's Avatar
SOCALHD
Shift Shaft seal. Common. Is it an actual Leak or a weap. If it is just oily in the area that is a weap and I wouldnt worry about it for now unless you have warranty. If it is dripping oil then it is a leak.
CSS_FXD
Jun 3, 2015 11:28 AM
balingwire
Nov 16, 2013 08:39 PM
Pagman
Oct 21, 2012 07:24 PM
Wayne Pilato
Jul 7, 2012 12:25 AM
Quickie
Sep 9, 2007 09:59 AM
