Drip, drip, drip.....
Old Jul 6, 2012 | 01:02 PM
Wayne Pilato's Avatar
Wayne Pilato
Unhappy Drip, drip, drip.....
2007 FLH that will not stop leaking at the bottom of the outer primary cover near the drain plug. I've changed gaskets, followed tightening sequence, and torqued bolts to spec. Any thoughts/experience on usingPermatex gasket sealant on the gasket?? One side? Both sides?
Old Jul 6, 2012 | 01:18 PM
Homebrew101's Avatar
Homebrew101
if it's just leaving a small spot about the size of a quarter or so IIRC it's probably the shifter shaft seal, mine leaked at about 10K
Old Jul 6, 2012 | 01:25 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Are you leaking primary oil or transmission oil. if you can get your hands on some UV dye put it in your tranny, do a quick 20 mile ride then shine a UV light on the oil if it glows it's tranny, if no glow it's primary oil.
Old Jul 6, 2012 | 02:00 PM
2kids3pets's Avatar
2kids3pets
my guess too, probably not the cover. The shifter shaft seal was leaking on my Deuce...I would just give it a wipe after each ride and never saw a drop on the floor
Old Jul 6, 2012 | 02:26 PM
oldairboater's Avatar
oldairboater
Find the leak and fix it.
Old Jul 6, 2012 | 02:29 PM
nvsteve's Avatar
nvsteve
Reach up onto the back side of the primary case. If it's oily it's the shaft seal.
I put Redline Shockproof in my last bike and it stopped leaking.
Old Jul 6, 2012 | 06:44 PM
FroggyFatBoy's Avatar
FroggyFatBoy
My FB was leaking the same exact way.. would drip a bit after it shut down.. drove me nuts thinking it was the drain plug, primary gasket.. tracked it down to the Inner primary bearing seal.. the inner sleeve walked out and left the outer seal lip riding against air.. luckily its a two lip seal and the inner lip keeps a majority of the fluid back..
theres a thread in the Primary Tech section.. a couple of pics..
Old Jul 6, 2012 | 06:59 PM
FroggyFatBoy
its actually a very poor designed shaft , hub assembly. they should have either left the sleeve out and used a smaller diameter seal and a bearing assembly with a inner race, which most are installing. Though just designing the damm sleeve to be longer to meet the back of the clutch hub would have been a einstein moment for the engineers.. . theres about a 1/2" gap between the sleeve and hub and this allows the sleeve to walk out.. just plain poor design..
Jim Kraft's Avatar
Jim Kraft
I put Mobil 1 75-90 synthetic gear lube in mine, and it started leaking. Went back to dino 75-90 gear lube, and it quit. Has not leaked for 10,000 miles anyway. That is in my 5 speed on my 99 EVO.
Old Jul 7, 2012 | 12:25 AM
oldairboater
If it is going to seep syn when find it. I still prefer syn but I did have to fix a few seeps.
Trex
Jul 30, 2019 09:34 AM
WideGlideFever
Jun 9, 2015 05:00 PM
balingwire
Nov 16, 2013 08:39 PM
Pagman
Oct 21, 2012 07:24 PM
FireRyder09
Nov 5, 2009 10:53 AM
