Smart Siren II Upgrade?
Once other question. Since I will be mounting this inside of the fairing, does this site offer a AM/FM antenna like the siren one that I can also install inside of the fairing?
Of course it depends on the objects and the buildings in the area but I would guess you will see 3-5 times the range if you do it correctly. All of my buddies that I've done this with (they all had 06 or older bikes) also saw their key fob range double. This mod has nothing to do with the key fob stuff but I'm guessing the parasitic coupling comes into play and the antenna brings those signals up as well. Both are on in the same 433 MHz band. Sorry for the techno speak. I'm a radio engineer by background and design this stuff everyday. The company that designed this module for Harley was nice enough not to make any of their design private when they got their FCC certification. That's the only reason I know so much about how it was designed.
Everyone I've helped do this has had a dramatic increase in range though.
Buy some 300 ohm twin cable from Radio Shack. Split it near the end into as long as you can get.. around 3 feet is good. connect one side to the sheild from your radio.. the other to the center conductor. My guess is you'll be OK. It's not perfect for sure.. you'll never get perfect doing a fairing antenna though.
Honestly, I've never worried about it on my bike because I can't stand commercial radio stations.
Either way, this is NOT rocket science... regardless of what they want you to believe. HTH
Try this antenna, http://www.ecshylites.com/catalog/it...191/721930.htmworks great in my bike faringand I am still able to receive the weather band.
The problem is two fold. First, the 6â antenna is a quarter wave antenna and requires a ground plane to work properly.
Second, the antenna is placed against the bike frame which detunes it and allows the bike to shadow the signal in some directions.
The solution is to replace the antenna with one that does not require a ground plane and to relocate it away from the bike frame and up as high as possible. I did this using the antenna shown below. Just remove the siren module and cut off the existing wire antenna and crimp the connector shown to the siren coax. If you canât do the connector crimp you can just solder the center conductor of the siren module to the center conductor of the antenna cable. Also solder the shields to each other. Just keep the exposed center conductor as short as possible. Mount the antenna (using its double faced tape) up into the lid of the tour pack. Route the antenna cable down and connect it to the siren module. You can get the antenna and connector at http://www.digikey.com
The antenna is part number ANT-433-MHW-RPS-S-ND
The connector part number is CONREVSMA011
Let me know if anything wasnât clear.
