Tried the battery still will not start
Old Jun 7, 2009 | 02:45 PM
lionpride1985's Avatar
lionpride1985
Default Tried the battery still will not start
It is not recognizing either FOB. The radio works, it whines when I turn on the ignition but it is not releasing the security system like normal.
I am going to try and disarm again but it would not let me put in a zero on the numbers. It said in the manual to fill in the odometer reading.
I really do hate being a dumba$$.
Old Jun 7, 2009 | 02:46 PM
lionpride1985
Also all the dealers in Dallas are closed on Sunday. Noone to call at Harley.
Old Jun 7, 2009 | 03:44 PM
rk62's Avatar
rk62
Re-read the instructions. It doesn't mean to enter your odometer reading. The PIN code you choose will display itself in the odometer spot one digit at a time. I hope this helps. By the way, you haven't mentioned the year of your bike on either of your threads.
Old Jun 7, 2009 | 04:11 PM
sgdiesel's Avatar
sgdiesel
The user manual is clear on this, no zero's are possible in the pin.
Can't seem to find it anywhere, but I am as sure as anything that the default PIN is 11111. There is a factory default as I remember this was the first thing I did when I took delivery of the bike.
I also know our dealer uses the manual override function all the time when they want to move bikes around, and 11111 is the easiest number to key in so that makes sense.
I must have got a sheet with that info on when I took delivery, weird that I can't find it
Old Jun 7, 2009 | 04:21 PM
stafford's Avatar
stafford
Try tapping the key fob on the switch housing or the handle bars , my brothers does that sometimes and that seems to fix it.
Old Jun 7, 2009 | 04:30 PM
deluxe drew's Avatar
deluxe drew
I *think* in the manual it lists 13131 as the default code...
Have you tried both of your key fobs?
Old Jun 7, 2009 | 04:33 PM
hogbag07's Avatar
hogbag07
Split the fob cover and pull the battery out and put it back in that fixed my fob when it stopped working last time. I think the first numbers on the compliance plate with any 0 turned to 1 is what Harley use on the security pin.
Old Jun 7, 2009 | 04:37 PM
emwolb's Avatar
emwolb
this might seem dumb, but if you have not had the bike running all winter and are trying to start it now, without it having been on a tender, etc, then the problem might lie in the bikes battery. is it charged well? and i don't know, but with my corvette if i change the battery in the fob, i also gotta marry it to the cars computer. might be the same way with the harley. try charging your bikes battery first. might help.
SCEGU
Dec 4, 2014 08:23 PM
Cdollaz24
Exhaust System Topics
Dec 11, 2013 06:11 PM
bswearingen
Jun 12, 2011 08:18 PM
Rick14221
Jun 4, 2011 10:30 AM
lkr0
Jan 6, 2008 08:24 AM
