CVO Rear Shocks
Old Apr 22, 2012 | 08:21 PM
sh4325's Avatar
sh4325
Default CVO Rear Shocks
I just installed a set of the CVO rear shocks on my 09 Road Glide. They work very nicely. I has the 13's that came on the bike. The CVO's are 12 inch and they still work better then the 13's. I like the 1 inch drop in the rear.
Old Apr 22, 2012 | 08:25 PM
Fire-Medic's Avatar
Fire-Medic
Love the ones on my bike once I set them up for my weight properly. And yes I agree, these are much more comfortable than the shocks on my old Limited despite being an inch lower.
Old Apr 22, 2012 | 09:36 PM
Northbound Southerner's Avatar
What did you do to adjust them? I have the same shocks on my RoadKing...
Old Apr 22, 2012 | 09:39 PM
Fire-Medic's Avatar
Fire-Medic
If you do in fact have the same shocks that come on my bike, behind the left saddle bag ( if your on the bike left side) there is a *** that you can turn to adjust pre-load. There are different settings on how many clicks for certain weight, each click you hear is at the half turn mark. If you need a setting pm me and we can go over the weight you need to set for. I hadn't done this until after I put over 1K miles on the bike in 4 days, and man what a difference when set up properly, lol.
Old Apr 22, 2012 | 09:50 PM
sh4325's Avatar
sh4325
You got it!
Old Apr 23, 2012 | 06:10 AM
I have mine set at zero clicks and it is still a bit stiff. I think I am too light for these shocks...they are much better than the stock ones but are still not super plush...
Old Apr 23, 2012 | 09:34 AM
bigskyroadglide's Avatar
bigskyroadglide
can these shocks be used on an 04 bike? i like the way they ride on my 12 but it appears they mount differently than the 04 shocks?
Old Apr 23, 2012 | 09:46 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
They mount the same.... but your swingarm won't be able to handle the stress of having compression and rebound damping split between the two shocks. One side is compression, and the other is rebound..... The later swingarms are a lot beefier.
Old Dec 26, 2025 | 09:39 PM
Tzler's Avatar
Tzler
Stage II
Your preload is set to rigid, lighten up on spring pressure, follow sag rules, very import to set proper sag 1st, then fine tune with ****...
Old Dec 26, 2025 | 11:08 PM
hattitude's Avatar
hattitude
He probably won't get your advice...
He posted that 13 years ago, and hasn't posted here since 2018...
You could try sending him a private message, but no guarantees he even still has the bike...
bo54gey
Dec 6, 2018 10:48 PM
Mofo67
Screamin Eagle CVO Models
Feb 15, 2017 07:20 AM
nsnorgrass
Stock Harley Take Offs
Jan 16, 2017 08:40 PM
Webo
Nov 6, 2013 09:48 AM
legendzzz
Jan 11, 2011 02:56 PM
