Leakdown results
Old Apr 27, 2012 | 06:41 PM
Born2cure's Avatar
Born2cure
Default Leakdown results
Leakdown results 15% front and back thru rings. Weird both equal but that's what dealer said. Bike running good but changing cams and exhaust tomorrow. Changing from woods tw7h to Andrews 54 also adding d&d Fatcat. Presently I have bubs truedule. Compression 200psi back 210psi front. My question if you decide to except it, is do I redo rings or let it be.
Old Apr 27, 2012 | 07:03 PM
roadglide65's Avatar
roadglide65
5 to 7 % would be my limit, 15% is a lot.
Old Apr 27, 2012 | 07:10 PM
mkguitar's Avatar
mkguitar
motor warmed to temp ?
if yes, maybe a re-ring- in which case the labor is the same to go to a big bore...
oh,oh. mission creep
mike
Old Apr 27, 2012 | 07:35 PM
Born2cure's Avatar
Born2cure
Thinking the same thing. Did 103 last yr with slight head work guess rings didn't set right. Not happy. I had another post earlier about my primary oil not a good day for my bike. 107 might be in the cards.
Old Apr 27, 2012 | 08:46 PM
tubeman426's Avatar
tubeman426
Personaly I wouldnt trust thier results, test it your self or try another shop. To confirm results, a bad or leaky compression guage can skew results. This has happend to me, I have two guages to confirm results. If both guages read the same then I concider what is wrong with the engine. Compression guages with bad orings or shrader valves can give you inconclusive results. I just lent a friend my compression guage, he was very happy to find out his was bad and not the engine. Just make shure there is a problem before you tear it down.
Old Apr 27, 2012 | 09:00 PM
Rooster37's Avatar
Rooster37
Way to much in my opinion... I would have a second opinion to make sure....
Old Apr 27, 2012 | 11:27 PM
piasspj's Avatar
piasspj
Both cylinders being the same is good. Strange that it is 15%, I'd suspect that there may be a problem with the test equipment or how it was done.
It might be worth having it checked again.
Old Apr 27, 2012 | 11:31 PM
SICKBAGGER's Avatar
SICKBAGGER
Definitely a second opinion, also if you change the oil and she goes black right away then it may be true as the carbon work its way right into the lower end.
Fat11Lo
Engine Mechanical Topics
41
Sep 13, 2017 12:08 PM
StevenTammy
Exhaust System Topics
13
Apr 1, 2014 07:42 PM
128auto
Nov 29, 2013 04:58 PM
jlinder
Mar 30, 2010 07:37 PM
SC-Longhair
19
Mar 1, 2009 05:52 PM
