torque wrench
Old Apr 28, 2012 | 06:35 AM
Sandcrab's Avatar
Sandcrab
Default Snap on
buy the Snap on, start with the 3/8" drive.
Old Apr 28, 2012 | 06:42 AM
sortasuave's Avatar
sortasuave
Personally I would go a little cheaper than the two you have here. One other thing, there are several specs in the HD shop manual that call for inch pounds. It's not hard to convert, but they are novice to have when working on the bike.
Old Apr 28, 2012 | 07:26 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Before I would spend that kind of money on a ft lb torque wrench from Snap On (a great tool company by the way), I would split it up and spend about the same on a couple of really good wrenches...a ft lb wrench AND an inch pound wrench. Forget about converting a ft lb wrench to inch pounds. The accuracy of the torque is not satisfactory and you will end up over torquing.
Old Apr 28, 2012 | 07:57 AM
hog95023's Avatar
hog95023
Lowcountry, the snap on has settings for newton meters, inch pounds and foot pounds all in one 3/8 torque wrench. At least mine does.
Old Apr 28, 2012 | 08:05 AM
HDstreetHOG's Avatar
HDstreetHOG
I have both and the 2nd one is probably used most.
and yeah, the Snap on ones are the best. IMHO
Originally Posted by CHILLLS
fore those of you who are mechanics i have a question.
i am looking at getting a digital torque wrench & mostly use it on my SG, now im not sure witch one to get the....
1/4" drive
2-20 ft lbs (24-240 in lbs)
http://buy1.snapon.com/catalog/item....re&dir=catalog
or
3/8" drive
5-100 ft lbs (60-1200 in lbs)
witch one do you think would cover more of the bike?
thanks in advance
Old Apr 28, 2012 | 08:31 AM
RK Joy's Avatar
RK Joy
You must mean 1/2" if it goes to 240 ft-lbs. Anyway, the one I use on my bikes is a 3/8" drive with about 100 ft-lbs top end. I don't think there are many things you will do yourself requiring more than that.
Old Apr 28, 2012 | 08:32 AM
turnerbend's Avatar
turnerbend
Get yourself a ft/lb and an inch/lb. you will need both. I would not pay $300+ for one. I got both and also the beam type which I use mostly. The high dollar wrenches will need calibrating quite often which is costly.
If you make a living wrenching, then maybe you need the top of the line wrench.
Old Apr 28, 2012 | 08:44 AM
DuraGlide's Avatar
DuraGlide
I have the second one. Great to be able to switch from in/lb to ft/lb with the same wrench. Mine beeps and vibrates when the setting is reached so you don't have to be able to see the readout when torquing. Also have a Snap-On 1/2 drive for higher torques like axle nuts. Its close to 30 years old and has never required adjustment when checked. And yes, I am a professional wrench.
Old Apr 28, 2012 | 08:47 AM
soft 02's Avatar
soft 02
Telling someone "if you dont wrench for a living dont buy snap-on" is like saying "if your not going to ride everyday dont buy a harley"! Man if you got the coin and want the best go for it. Over kill for the shade tree yes but holding the best tool made priceless.
Old Apr 28, 2012 | 09:34 AM
1fathog's Avatar
1fathog
I used the 3/8 SnapOn TECHWRENCH TECH2 does IN., FT. & NM
