5th Gear Slipping
Old Apr 28, 2012 | 10:42 AM
piasspj's Avatar
piasspj
Does it only happen in 5th gear? I would suspect that a clutch issue would happen in all gears and be worse in 6th where clutch slippage would also cause the 6th gear indicator light to flicker or turn off.
Old Apr 28, 2012 | 10:46 AM
1Canuck's Avatar
1Canuck
I had adjusted my clutch to engage about 3/4" off the bar (my preference), no slippage in 5th. went to the dealer to complain about the compensator issues. of course it was normal. Left dealer and immediately noticed clutch engaged near end of lever release, hit hwy and yes 5th gear slippage. got home readjusted my way and no more slippage. at this point it was stock clutch spring.
Old Apr 28, 2012 | 11:34 AM
Trial dog's Avatar
Trial dog
Actually it apparently is not an unusual problem. What I have seen as an explanation has to do with torque but it doesn't make sense to me since it seems like I could generate more torque in lower gears at high rpm. Regardless, I have seen at least 4 or 5 threads in the past discussing this issue.
Old Apr 28, 2012 | 12:49 PM
bklynbob's Avatar
bklynbob
www.bakerdrivetrain.com/f6f-factory-6-fix
and install a 31 tooth pulley and you'll be very happy...........
Old Apr 29, 2012 | 08:29 PM
K Melancon's Avatar
K Melancon
More strain on clutch in higher gears, just like the engine. Engine doesnt straing in low gear if it did you would not be able to go to a higher gear because it would stall the engine. It probably not doing it in 6th because he is only cruising
Old Nov 8, 2012 | 06:47 PM
avipman's Avatar
avipman
Stage III
I have a 2012 RGC with 4800 miles on it at the Harley Dealer now for the same problem. They changed out the Door Bearing and did a test drive. Bike still slips in 4th and 5th gear with a load on it. Their suggestion is to replace the clutch with a Screaming Eagle clutch.
I called another non-dealer shop and they said most likely its the spring. I tend to believe them because I only get the slipping when at 3000 RPM's in 4th or 5th gear when I get on it. If it were the clutch, I would be experiencing it in other gears...
Changing the spring next Wednesday....
Old Nov 8, 2012 | 07:21 PM
Chunker's Avatar
Chunker
Is this a new bike to you, or have you, or someone else, recently changed the primary oil? If so, I would drain the primary, fill with a good "non energy conserving" 10w40 dino oil, run it a bit to flush it out and repeat. If that doesn't help then look at the mechanical side.
Old Nov 8, 2012 | 07:32 PM
rgregory's Avatar
rgregory
This is my first post, but had to jump in here. I have a 2010 Ultra and had the same issue, only slipped in 5th as I would exccelerate. When I took it in to the dealer they were VERY aware of the problem and had to pull the trans and replace some bearings. Didn't totally make scence to me but it work. All covered under warranty too!
Old Nov 8, 2012 | 08:59 PM
Flintshooter54's Avatar
Flintshooter54
There was an issue I heard about that in fifth gear the way the gears are cut it puts some sideways thrust to the transmission shaft. IF the bearing has any end play (Axial movement) it can push out slightly on the clutch and make it slip. The result according to the article was you can get a new bearing or a stiffer spring. The spring overrides the end play movement.
Old Nov 8, 2012 | 09:50 PM
deadhawg's Avatar
deadhawg
I'd start with the simple stuff - is the primary oil level correct? A high oil level can cause foaming and clutch slippage. I've heard that some synthetic oils can cause clutch slippage, though I've used Syn3 and Mobile1 synth with no problems. I'd try changing to regular, non-synth primary oil before spending the cash for a clutch job.
Are you adjusting the free play at the clutch itself? Adjusting the cable is only part of the process for proper adjustment.
thumper89
Jul 26, 2019 07:27 PM
W0ace
Dec 3, 2015 09:16 AM
1Jumper
May 29, 2013 09:16 AM
tailfinn
Nov 13, 2012 07:58 AM
bulldawg10
Nov 6, 2010 03:53 AM
